Question about Ice Cream Makers
Replaced the shaft gear that cracked .The machine runs but stops when the ice cream starts to get cold.What could be the problem.I have an old machine for parts.
  • 4 Answers
SOURCE: Musso Ice cream maker freezes and then heats up during use
go to Http://www.catering-machines.com they have full list of spares or parts for Musso stella.
All parts for the musso ice cream machine including lid, motors, gear wheels, gearbox, musso paddle Musso serial numbers start L1 = Musso piccolo L2 = Musso stella L3 = Musso Club L4 = MUSSO CONSUL.
Posted on Jun 04, 2009
  • 3 Answers
SOURCE: Taylor Y754-27 Soft Serve Ice cream machine
gearbox is sealed, I've never replaced one.check belts could be too tight, does it scream when you start it. check bearing at end of barrel sharp edge means needs replacing. check temperature of product disspensed on loud side could be too cold. adjust on board or needs new probe, inexpensive but a ***** to install.
Posted on Jan 21, 2010
SOURCE: Spares for Taylor 8756 ice cream machine
looking for 777 741 770 beater blade
Posted on Feb 22, 2010
  • 3 Answers
SOURCE: dak gelatisimo machine broken gears
The following Gates belt will work. Its called Poly power chain belt which is metric and just under 12 inches with 60 teeth. Just Google the number and you will find several suppliers online. Costs around $24 which is cheap to fix such a great machine.
Product # 5MGT-300-09
Posted on Mar 06, 2010
  • 15 Answers
SOURCE: Motor does not stop
If the ice cream is frozen on the inside of the can and soft toward the center, I would check your paddles. The paddles are wooden and they attach to the outer dasher with two screws. If the screws are too tight or too loose, then the paddles will not scrap the frozen cream from the inside of the can, resulting in what you describe.
Posted on Jul 16, 2012
Where can I get a gear wheel that takes the paddle shaft. Teeth have broken off mine.
Alan, there unfortunately are not any canister ice cream makers that the manufacture sells the replacement gear wheel.
Unfortunately when you have gear issues or motor issues there are not any replacement parts and they have just become a throw away item.
Mar 29, 2015 | Ice Cream Makers
Drive shaft stuck
if you can't get it out thru the barrel then you will need to remove the gear box behind the shaft and push it out that way. you should align the shaft afterwards to not rub also make sure your not lubing the bolt pattern on the shaft. after its out use the cleaning brush and clean the coupling.
Mar 02, 2013 | Taylor 794-27 Soft Serve Twin Twist Water...
Is there a trick to removing the shaft that turns the beater on a Taylor ice cream machine? I often have trouble removing one or the other shafts when cleaning the machine.
Most likely your alignment is off on the gear box that has the coupling attached to it, you can try to lift the box up alittle after loosening the bolts and just tighten one and recheck until it pulls out freely with no effort
Jul 25, 2011 | Taylor 632-27 Ice Cream Maker
My motor runs but doesn't turn the ice cream container. This is before I put in any ice or salt. It starts to turn then stops.
The gears are bad inside the gearbox...
Hereis a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Apr 01, 2011 | White Mountain F69206X 6 Quart Ice Cream...
I have an old Simac Il Gelataio Super. I believe the clutch is broken. It will only churn until the product is very soft. Then the blade stps because the drag on the sides is too great. Is this...
It sounds like the main gear is cracked were the paddle shaft goes though it.the d shaped shaft is spinning when the ice cream gets firm. i repaired mine by making a sleeve out of copper pipe and slid it over the cracked part. works great.
Dec 11, 2010 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Rival icecream maker
Perhaps some gears are breaking inside the motor? If you need parts, they are sometimes available here: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=rival+ice+cream&submit=Search&_sid=93311479
May 27, 2010 | Rival 8401-M 4 Quart Ice Cream Maker
Gearboxes definitely go bad. The first sign is usually noise, I would describe it as a rumbling. The best way to determine if it's the gear box is:
1. empty and disconnect machine from power.
2. remove the freezer door and beater assembly
2. remove the rear panel - 4 screws
3. Remove the belts on the noisy side
4. Spin the big pulley and listen for the noise, you may want to remove the belts on the quiet side to compare the two.
I have a video that was shot to help change the hex coupler, but you would follow all of the same steps to replace the gear box.
Dec 12, 2009 | Taylor 632-27 Ice Cream Maker
OUr rival 8550-x 5 quart wooden electric ice cream maker doesn't turn the blade in the canister. The motor is running but the blade doesn't turn in the canister.
take it apart and find the striped gear the motor actualy turns at 2000 rpm and has a reduction unint inside
eithor the gear is striped or the grub screw fell out of the drive gear could also be a drift or sheer pin on the main shaft
Aug 03, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
I need to buy a new Ice cream well/ bowl
Apr 29, 2009 | Musso Stainless Steel Pola Ice Cream Maker
Jan 14, 2008 | Musso Stainless Steel Pola Ice Cream Maker
Ice Cream Makers Logo
177 people viewed this question
Top Ice Cream Makers Experts
ray gallant
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
