I have a bekkestua base But there is no where to fix the legs to
This front load washer is unbalanced all the time and shakes the whole house. Is it worth it to fix it?
Yes of course it may simply be a balnce problem, the legs need to be re adjusted. I use a level to check the balance. adjusting each leg accordingly, another thing it might be is that the counter weights balance rods are needing replacing or re greasing with lithium bases greased
Apr 11, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
Hi, I have just bought the 190CXPRO3 carbon fibre
Little confused here. Is the head the part you want to detach from an older set of legs? Do you want to remove center post from new legs or old legs. The base plate remains on the center post/ Aftre removing 3 set screws, and you want to remove the head from the baseplate and it will not turn, grap slip joint pliers or a pipe wrench, wrap the jaws with cloth ( to prevent marring of head or legs) and while holding head with wrench, have someone else turn legs
Apr 26, 2011 | Manfrotto (190XB,128RC) Tripod
I want to wall mount a FX2490HD and cannot remove the base I have remove the screw form the back but the base will not move
Hi, there are two screws underneath the legs of the stand and one other screw to hold the attachment that the legs connect to. If you have removed all three screws then try swiveling the legs.
Feb 12, 2011 | Samsung Televison & Video
I cannot get the support leg for my maxi cosi base detached. Any ideas
The support leg on the base cannot be detatched. It is part of the safety feature on the base and should not be removed.
Nov 07, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
I want to hank my toshiba 42-95plasma tv on the
Toshiba has about six screws holding the base legs on remove them and pull the base straight down till the legs come out all the way
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 25, 2009 | Televison & Video
Volumen to conecting to circuit
Center pin goes to R115 right leg goes to C84
witch leads to the base of TR10 left leg to
ground.this is off aschematic of 25 LTD should
be close.
Good luck
May 23, 2009 | Cobra 25 NW LTD 40-Channels Base CB Radio
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
