Baxter ov310g tripping breaker. What can cause this?
3 Suggested Answers
  • 234 Answers
SOURCE: My bunn is causing my breaker to trip
The heating element going bad in the coffee maker.
Posted on Mar 17, 2009
  • 3640 Answers
SOURCE: Coffee Maker is causing breaker to trip
there may be to many things on that 1 line. go to another outlet to check if this is the problem.
Posted on Apr 30, 2010
My Rinnai tankless water heater keeps tripping the breaker then when turned back on, it begins to beep and displays a code 12. What is causing this? It is new and this is the first time any code came.
Go to Rinnai and get a manual with the error codes... for example a shorted element will trip breaker... wiring problems can cause breaker to trip... anything that causes heat on wire to exceed amp rating of breaker will cause it to trip...
http://waterheatertimer.org/Water-heater-is-tripping-breaker.html
Sep 12, 2017 | Rinnai Water Heaters
TRIPPING BREAKER
get in an electrician to check the equipment and the circuits
Aug 29, 2017 | Heating & Cooling
I have a problem with baxter oven ov310g powering off automatically. Have to turn breaker on and off again to reset. Any advice?
it could be a element blown to earth, if breaker is tripping when oven off wiring fault
Dec 09, 2016 | Baxter Ovens
Baxter oven does not fire up at all
So many things it could be. A bad high limit switch. A bad air proving switch. Maybe the burner motor overload had tripped. And that's not even half of the components that might be preventing it from working. It's best to call an experienced service provider.
Oct 14, 2016 | Baxter Ovens
Oven doesn't give steam but it does reach the temp.how can i fix that?
First locate the water solenoid valve. Disconnect the water line to the inlet side of the valve to make sure water is getting to the valve. Once that's verified, disconnect the outlet side of the valve. Activate the steam and verify that the valve opens and there's a good amount of water coming out of the valve. If no water comes out. Verify that the coil is getting energized with the correct voltage. If the correct voltage is present and you have no water coming out. Replace the solenoid. If everything is working then remove the left panel inside the oven to check for blockage in the steam manifold. The manifold consists of a pipe with several spray nozzles that spray water on rebar. Remove all the nozzles and activate the steam. Do this several times to purge any rust or debri. Clean the nozzles and replace them. You should be good to go.
Aug 25, 2015 | Baxter OV310G Mini Rotating Rack Gas Oven
Breaker trips on startup
If your circuit breaker is tripping when you turn the pump on it is caused by a bad motor. The motor probably has a short in it causing the breaker to trip,
Replace your pump and that should solve your problem with the breaker.
There is an outside chance you may have a bad circuit breaker too.
US Parts Center
Sep 02, 2013 | Jacuzzi Home
Wich is the power supply 120v, 208 1 phasse or 208v 3 phase.
Most Baxter BXA ovens have separate power supplies, usually 120v for the controls and lights, a 120v output on a circuit breaker for the roof fan, and a 208VAC 3 phase supply for your convection motor. Older Baxter ovens may have a 3 phase service disconnect inside the electrical/burner compartment, if I recall correctly the BXA models do not and the only way to shut it off is via the 3 pole breaker at the service panel.
Feb 04, 2011 | Baxter BXA2G Stainless Steel Gas Single...
When #9 program for Bagels is running , the temp drops 130 degrees before cycle is complete. also having to reset breaker several times
It's normal for the oven to drop temperature during the first 4 minutes of a bagel cycle, although the temperature should recover to 525 before the end of the bake. If your breaker keeps tripping you could have a blown heating element and should call your local authorized service provider, I wouldn't recommend attempting to repair this one on your own.
Sep 28, 2010 | Baxter OV300E Stainless Steel Electric...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
