Question about Maytag PAV2300 Top Load Washer
Hotpoint washer model WLW1500BALAD - continues to fill with water
Won't stop filling with water after spin cycle starts, so it overflows and floods. This is an older top loading model. What needs to be fixed and is the cost worth it considering the age? I was told it needs a new valve?
Thanks
Scott
SOURCE: Top loading Maytag washer Model
When the machine worked would the machine stop in the wash cycle when you lift the lid? If so you might check your lid switch.
Posted on Jul 16, 2008
  • 36 Answers
SOURCE: maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Posted on Jan 03, 2009
jumptrout51
  • 3361 Answers
SOURCE: maytag top loading washer won't agate.
Open your control panel.
Disconnect then reconnect your timer wiring harness.
If this does not correct the problem,replace the timer.
Posted on Feb 25, 2009
SOURCE: Maytag Top loading Washer, fills but won't stop
there is a small tubing about 12 inches or so that connect from the water level dail to the tub of the washer. sometimes the clamp on there gets loose and that interfers with the communication. try changing the tubing and or just tighting the clamps. you will need to lift the top of the washer off to get to it.
hope this helps
Posted on Mar 17, 2009
farfield
  • 462 Answers
SOURCE: Maytag Washer PAVT-1 continues filling with water to overflowing
Does it still do this with power to the machine off? If so it is your water fill valve. Because no power is getting to the valve it has to shut off unless some foreign particles are holding it open. Remove and replace the water fill valve if still runs water after power is off.
Here are some things on how the selector switches work: If it stops when you remove power look at these possibilities.
Water fill switches usually have an air tube that as the water level comes up the air pressure increases and causes the switch to go from fill to wash.
I have seen rodents chew holes in the air tubing and this could be the cause or you may have a bad switch.
Some times the switches also get out of calibration and need readjusting (especially if you have moved in altitude like up a mountain or into a valley).
If this helps you please rate me as high as possible.
If it doesnt help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
Posted on Mar 24, 2009
In the begining of was the water won't stop filling, it overflows and it won't go to the wash cycle (adjetate) however I can turn it to the rinse cycle and it will drained and spins?
Possible that the water level sensor has failed.Shut down washer and trace the sensor which is a pressure activated switch from the drum overflow. the switch can be activated by blowing and checking continuity. if so replace the unit
Dec 30, 2012 | Whirlpool Washing Machines
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Water Overflows from washer
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 18, 2009 | Kenmore Washing Machines
Won't stop filling basin and doesn't agitate.
check your pressure level hose. it probably pulled off at the tub or the pressure switch
May 18, 2009 | Hotpoint VBXR1090D Top Load Washer
Whirlpool Estate Washer will not stop filling.
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Apr 16, 2017 | Estate ETW4400VQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Nov 08, 2007 | GE WDSR2080D Top Load Washer
Lavamat 6955 sensorlogic - carries on filling until water overflows from soap tray
fault f1 is slow or no cold fill. this fault code with overfill points to: air chamber blocked with sludge hose from air chamber to pressure stat blocked or split pressure stat faulty of these the first is the most likely
Dec 12, 2006 | AEG Lavamat 88840 Front Load Washer
Maytag PAV2300 Top Load Washer Logo
113 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
