Question about Cell Phones
My phone is on roaming for some reason ..and I am not roaming
What is data roaming
Data roaming is simply cellular internet data but using out of your country. For ex. when you go on holidays to Spain you can use cellular internet from roaming. Roaming is for calls and sms too. And important thing is that roaming is much more expensive then normal in your country
Jan 08, 2015 | Cell Phones
Tip
Key Benefits of Using an Unlocked BlackBerry
Thousands of people around the world are using unlocked blackberry due to these several reasons,if you are frequent traveler or just cant bear the outrageous costs of expensive contracts then you should seek unlocking your blackberry...
Eliminate Roaming Fees - Roaming charges can drastically increase your base mobile phone bill every month. These roaming charges are based on either your current cell phone contract or the limits of service areas that your provider offers. Unlocking your mobile phone can eliminate roaming fees by allowing you to change the SIM to lower priced networks or local networks when traveling
Increase Resale Value - When you decide to upgrade to a new phone, it also time to sell your old one. Unlocked mobile phones are easier to sell up to 300% more valuable than a locked one because they are compatible with more networks, which means there will be more potential buyers for your phone.
Use Any SIM on Any GSM Network - With an unlocked mobile phone you can change carriers without buying a new phone. This means you can take advantage of the best service package for your current needs. Then if your needs change, you can change providers.
Save with Local Rates - An unlocked mobile phone allows you to take advantage of cheaper rates from rival networks as well as attain an ability to use local service providers while abroad. This will drastically cut down on your tariffs for text messaging and calls home.
Global Connections - Unlocking your phone may also enable dual, tri or even quad band functionality on your mobile handset. This means that your cell phone will be usable in even more countries around the globe as well as being a more valuable resale item. There is no longer any reason to own more than one cell phone handset.
Dual SIM Adaptors - When your phone is unlocked, there is the possibility of applying a dual SIM adapter, which allows your to have two SIM cards in the same handset. This makes your cell phone a much more versatile tool, for example you can separate work and leisure calls. Switching SIM cards can become as easy as turning your cell phone off and on again. You are in complete control of your mobile phone!
Expanded Service Area - Being free of any provider restrictions allows you to increase your areas of service without roaming charges.
Permanent Blackberry Unlocking - Your blackberry never gets relocked and is unlocked forever.
No Warranty Void Risk - Absolutely no risk of damaging your phone and warranty also doesn't get void.
Flexibility to use 3G and Data Settings - Use all Data and 3G settings as given by your Network provider on your unlocked blackberry
How to Unlock:- BlackBerry Unlocking instructions
on May 05, 2011 | Cell Phones
Smart roaming problem
consult you your telco about roaming. the country youre in for roaming probably not support your telco or simply having technical difficulty at the moment
Oct 16, 2013 | Cell Phones
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
My phone don't get no signal.
"My phone doesn't get any signal"
If you bought the phone out of state, you could be roaming which would be one reason you have no signal. If your in a rural place that could be another reason.
Jan 25, 2011 | HTC G1
I cannot send or recieve calls on my phone, unless its in roaming
You may not have coverage in your area unless your roaming, call your cellphone carrier and ask if you have service at the location! if you do you may have an issue on your carriers end, call tech support and ask whats going on.
If you can make calls whilst roaming, there should be no reason you can't when on your normal carrier.
Aug 27, 2009 | Samsung Highnote Cell Phone
Samsung u340 won't show roaming or not
you may wont to contact cricket and get verification on your service area........the roaming triangle should only apply to the device main screen when the towers being used have a roaming contract with the provider. you may very well be roaming but not from your device.....you may be roaming in the cellular network though.....contact cricket from another device for troubleshooting options at (866) 274-2538
GOOD LUCK !!!!!!!!
Apr 11, 2009 | Samsung SCH-u340 Cellular Phone
Sanyo pm 8200 sprint service no signal
Not sure about the bars, but you can go to the settings in the main menue and try to go to roam only. It could be that you r carrier is having a problem with their tower. Your phone, normally, will try to stay on your carriers towers. If you force it to a roaming status, you might get a better signal, but on a roaming network.
j
Jun 24, 2008 | Sanyo PM-8200
Nokia 6234, New Zealand. Vodafone.
get new sim card
phone carrier will copy whats on sim to new sim card i didnt get charged for this i dont think they will you either
the roaming overseas always changes parmeters of phone for some odd reason
May 10, 2008 | Nokia 6230
Roaming indicator
Reason for the lock code is because roaming charges are costly. In case you lose your phone and the person that has travels out of the country with it, he/she will not be able to make calls.
Mar 19, 2008 | Samsung SCH-u740 Cellular Phone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
