Question about Dishwashers
Water flooded kitchen from pump help - Dishwashers
    Top Expert:
  • Dishwashers Master
  • 8,204 Answers
Then you will need to look and find where it is leaking from and seal it up or replace the part thats leaking.
Posted on Dec 09, 2016
Dishwasher floods kitchen
I've got the same problem. They have a pump that sumps out the dirty dishwater and a float that tells them the water level. Food and calcium deposits make things bind up. There is rubber seals on the door that need to be just right. "Dishwasher floods kitchen" doesn't really help much. I knew my pump was clogged or bad because it wouldn't drain. I haven't fixed mine. We have an Amana and it never did a good job cleaning anyway.
Jan 03, 2015 | Dishwashers
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
Dishwasher pumping water but not dishwasher not in use
what is your model number is then we can get started then okay
Nov 25, 2012 | Dishwashers
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
Flooded the kitchen, spinning but not pumping out water
Usually an indication that something is caught in the pump inlet. You will have to remove the hoses and see if its a sock or some other small treasure..
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Keeps flooding: pump comes on when switched off.
This sounds like an inlet valve problem, Replace it. Often a dirt particle gets in the valve.
Nov 01, 2009 | AEG 18 in. Favorit 44630W Slim-Line...
Housekeeper put dish washing soap in - machine is full of bubbles. How do I clean it out without flooding the kitchen?
Turn off the hot water supply to the DW. Take a pot or pan. Fill the DW tub with COLD water, pump it out. Repeat this COLD water and pump out several times until the suds are gone. HOT water only makes the suds worse and prevents the pump from expelling the water.
Jul 07, 2009 | Bosch Dishwashers
Hi i have a technik dishwasher it has flooded the kitchen, i managed to get all of the water out of the machine but now the pump seems to be running all of the time, someone has told me there is a flood...
drain pump is running all time because there is water in bottom tray. tilt machine back to 45deg and water will flow out. otherwise, take front panel off and mop water out. alll that is required to reset flood switch is to get rid of the water
Jul 20, 2008 | Tecnik Dishwashers
Diplomat 8352 water not draining caused kitchen floor to flood
your pump is obstructed. take out pump and clean it out. Your filter might be plugged too. As soon as it floods it also can be a leaking hose from the pump.
just open the machine and you will see the pump straight away.
Not difficult
Apr 26, 2008 | Dishwashers
La Trisha, There could be many reasons for the leak, however usually all leaks are visable. Your model is a direct drive pump and motor and I have seen a lot of these pumps go bad and leak. You will have to remove the front panel. There should be 2 clips, one on each side of the washer top. Push a putty knife in these clips and the front panel should pop out from the top. Now you will be looking right at the pump on the bottom. It is held on with 2 clips and 2 clamps, a real easy fix. When you remove the front panel, let the washer fill a little again and see if the water is pouring from the pump. You will also be able to get a look at all the other hose attachments. The part number for the pump is 3363394. Good luck..
Jun 17, 2006 | Whirlpool LTE5243D Top Load Stacked...
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
