Question about Konica Minolta bizhub Office Equipment & Supplies
Closed 1st side cover konica minolta bizhub 185
Sir in my machine there was paper jam , but I had removed that properly.After that It start showing 1st side cover is open error massage, but side cover is duly closed.It have tried my best cleaning and closing again and again but in vain.The Problem is still there. Please help..............
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Check the 2 actuator at Right Door assy, may be broken, so while closing it is not blocking/hitting the sensors on body.
check properly - at Rear-Top & Front-Below on Right Door assy.
Posted on Dec 13, 2016
My konica bizhub 163 gives massage 1st side cover open close 1st side cover,how do i clear the massage. pliz help me.
1st Side cover is front cover.The cover which you use to open to install or check toner bottle.When you close that cover and machine gives caution then it means cover is not properly closed
The 1st side cover switch is not working properly.
There is a knob at the end of the front cover, make sure it it aligned with the switch.
Front cover Micro Switch can be dirty due to toner spilling/dropping inside the machine.Clean it and then recheck.
Jun 20, 2015 | Konica Minolta bizhub Office Equipment &...
I am having L code errors on our Konica Minolta Biz Hub 363
#10 Transfer roller needs replacing sponge looking roller right side of the of the machine when you open to remove paper jams.
# 9 Developing unit needs replacement that the part that holds the drum and developer/toner. IF YOU YANK THIS UNIT OUT WITHOUT REMOVING THE LITTLE COVER ONE BOLT and DICONNECT THE CONNECTOR. BIG TROUBLE, going to cost a lot to repair.
#8 PAPER DUST REMOVER the device that collect paper dust yes paper does produce DUST. Just before the sponge roller
#6 IS Warning that the developer has not been replace inside the drum cartridge. SEE #9
#4 Drum need to be replaced.
Really have to watch for all of that sir/mam.
Apr 11, 2014 | Konica Minolta "Minolta Bizhub 363 Copier,...
Misfeed detected
have the rollers been replaced, misfeed means the rollers cant grab the paper not a JAM
Jan 30, 2014 | Konica Minolta Office Equipment & Supplies
Open 1st side cover/ paper jam
did you open and remove the paper if so if its still ding it either the sensor is out of place or bad or the tab the on the door that acturates the senor to tell the printer door /cover is close is broken
Nov 15, 2013 | Konica Minolta Office Equipment & Supplies
Bizhub 500
There is another cover at the down right side of machine.Below the side door.Open it and then close it.Then bring out the tray and close it.Machine will start working.if not then tell me...
Nov 15, 2011 | Konica Minolta Office Equipment & Supplies
My brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Apr 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Hello sir; Are you using duplex unit, check your duplex unit.
Oct 13, 2009 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
235 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
