I have an Aquarius wf640 and it seems stuck on fast spin. I can t reset the programme. Apart from that it works perfectly....when I manage to get it to work that is Thnx Penny
  • 25 Answers
SOURCE: Spin problem on Candy CN450 Washing Machine
Posted on Dec 14, 2007
  • 139 Answers
SOURCE: Hotpoint Aquarius WF640
check your water supply to the machine is of adequate pressure . this is the sign when the machine is not getting enough water
Posted on Dec 16, 2007
SOURCE: WD440 Hotpoint Aquarius Rattle
Hi man - heres the fix if ever your WD440 stops and wont spin - and the off/on light flashes along with a couple of other lights like crease free etc etc.
Basically take off the bottom part of the back of the machine, its plastic - about a one foot by half a foot rectangle.
Oh yeah - plug it out :)
Look in the machine - you'll see a large jubelee clip or hose clip, google these for pictures if your unsure what they look like.
It will be connected to a wide - teenager size fist - black hose.
unscrewing the jubelee clip will losen this off.
pull the black rubber hose down to disconnect from the drum.
Get the mop - there will be a flood.
look inside the black hose, there will be a beutiful bounty in it - in my case I got 1 Euro 28 cents in a vast array of coins, a piece of sticky tape and a hair clip, which is ironic as I am bald.
fix the black thing back to the drum, retighten the jubelee clip, fix the plasic shell back onto the back of the machine... plug machine back in... push machine back into position.... taking care not to slip on wet floor.
approx fix time... 2 hrs to google for this solution, and then 5 mins fixing machine - 40 mins mopping floor.
all the best
Posted on Mar 11, 2009
  • 25 Answers
SOURCE: test light
Press and hold "on/off" and "start" buttons together for five seconds.
Posted on Jun 03, 2009
  • 552 Answers
SOURCE: Hello my washing machine works fine but when it
The drain motor may be bad click on the link below
Posted on Mar 08, 2011
What does f-5 mean when flashing at me and won,t let me have my washing out the machine also washing really hot after a fast spin programme
if water is in drum then door wont open,drop drain hose to floor level into bucket to drain manually, then check filter or pump is it running ok if not is it stuck some thing in it , hot wash is cold water inlet ok or is this due to again faulty pump ...
Jun 25, 2010 | Hotpoint Aquarius WD640 Front Load...
I have washing machine Aquarius wf640 + it keeps showing f-02
F02 indicates that the motor tacho has broken or become detached, this is to be found on the end of the motor shaft.
Pleawse rate my solution.
Aug 07, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf000 not completing final spin
u should check the drain filter and try to listen to the pump if its working
or the outlet hose might b stuck
May 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Test light
Apr 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Crease reduction facility won't work
Crease reduction facility is just a slower spin cycle if you coose a delicate wash there will be no apparent difference
Mar 07, 2009 | Washing Machines
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF340 - wont complete programme
hi without looking at it i would think that the control board behind the timer knob has broken down these can quite pricey so shop around before you buy one,hope this helps.
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wf640 test
This has happend to me today! this is the fix
  1. Press and hold the Start/Cancel button until message clears
  2. Now press both Start/Cancel and On/Off buttons together until you get a dOFF message
  3. now your machine should work OK
Mar 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
