Question about JVC Audio Players & Recorders
JVC FS-SD990R (CD shelf system) performs all functions with remote & unit buttons, but switches itself back to standby after 3-4 seconds. Power disconnect resets for the whole scene to be repeated.
Relay clicks when powered off. No obvious bad connections or dry joints internally. Any suggestions appreciated.
  • JVC Master
  • 5,318 Answers
More than likely it's a safety feature because it has detected a short circuit. Perhaps in a speaker connection? Or maybe in the power amp stage. Check out the device's on the heat sink.
Posted on Dec 18, 2016
  • 64 Answers
SOURCE: No Power
The click might originate from the cd mechanism, you might be expriencing some electrical display problem.
Posted on Mar 01, 2006
  • 3130 Answers
SOURCE: CD won't spin
Im afraid the laser is worn out, or there is a power supply problem, or the spindle motoer servo curcuit is defective. If you know how to service solid state curcuits, maybe it will be worth fixing. Im sorry to say, if you do not, then most likly the repair will exceed the cost of a new unit or come close to it. Good Luck PS please do not forget to rate this thread.
Posted on Oct 17, 2006
  • 752 Answers
SOURCE: Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
Posted on Sep 18, 2007
SOURCE: Sony MHC-GX9900 Shelf System
i have the same problem with the blinking light this problem is due alot to over heating be careful your fan is not burned up or is not being blocked it is a protect mode activation to prevent overheating
Posted on Aug 25, 2008
  • 62 Answers
SOURCE: mini hi-fi JVC CA-FSX3 stops after power on
Well, I disassembled the unit carefully. And I've found that diode SR303 was blown. It's very easy to find near huge pulse-code converter chip. This diode is used at power supply stabilization for amplifier that has a D-class i.e. pulse-code amplifier, and for CD part. Testing of this diode confirmed that it's dead. After a couple of days received the diode from shop, is very cheap. Changing the diode recovered all the functions of the unit. Now it works fine.
Resume: The diode was burned as a result of incorrect connection to line input. The owner of the unit haven't seen that a volume level was at maximum. The connection of line input overloaded the maximum current capacity of the diode and it was blown. As for it, I've seen that in that circuit in reality must be used a stabilization chip, that is not so cheap like a diode. I think it's a constructor's error to change the chip, that is overload protected, to a simple diode.
Waiting that my info will be useful because it´s a most vulnerable part of JVC CA-FSX3. And don't overload the amplifier!
Posted on Sep 10, 2009
My JVC FS 5000 cd player won't turn
check out the power supply all the way upto the switch on button ...
Jan 25, 2015 | JVC FS-5000 CD Shelf System
How do i make my unit continue through all ten cd,s without stopping in between? my unit is a jvc pc xc70
Once you've loaded all 10 the "continue" button on your remote, then press the cd play button directly beneath it.hopefully you have the remote controller...if not...there are similar buttons on the unit itself.
Sep 03, 2011 | JVC PC-XC70 Shelf System
Won't power on
I had the same problem. I just took it into a certified repair place. cost me 50 bucks to learn what part needed to be replaced and that it isn't available any more. Recyle it.
Nov 07, 2009 | JVC FS-2000 Shelf System
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
No sound coming from JVC FS-SD7
You burn out the audio amplifier IC you need to replace him
Mar 28, 2009 | JVC FS-SD7 CD Shelf System
Error code "protect" comes on the scree when turned on
This a memory problem ,try to look for the reset button and press it . If you can't find the reset button then the other option is unplug the unit for 24 hours the purpose is to reset and dessipate or drain the charged current .
Hope it may help you;
Jan 08, 2009 | JVC FS-G5 CD Shelf System
System automatically shuts itself off after a few seconds.
I have no Idea, I have My JVC system sitting in a closet. I got it in 2004, and It was working fine, and all of a sudden it stopped and went into protect mode. I have no idea what to do about it.
But this is what I did.
I unplugged it and I let it sit for 24 hours to see if it would Reset the microprocessor, that did nuttin'. So I took it apart ^_^ That was fun! and I checked all the wires for loose connections, and I made sure te cables were in there tight. My unit is a pretty old though, I have a surround sound system, but usually a good blast of canned air may clean the circuit board and the components.
Mar 03, 2008 | JVC MX-KA3 CD Shelf System
Jvc mini system cd bay will not open
Does your stereo have a childs lock? If it does; why? Anyway the cd open button could be defected. Possibily a loose connection on the cd open switch on the inside of the unit. Also dose the remote have this function? Check the battery. Clean the remote sensor on the front of the remote and on the stereo.
Hope this helps.
Dec 27, 2007 | JVC FS-G5 CD Shelf System
CD player is locked
Hell Yes!!!  Thanks my friend - I haven't been able to use this thing for about 6 months.... You da man!
Feb 07, 2007 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Cd player opens when turned on and will not function
JVC recommends leaving the unit unplugged for 30 minutes to reseet the system - I'm trying that now, and will keep you posted!
Dec 07, 2006 | JVC FS-G5 CD Shelf System
107 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
