Question about Electrical Supplies
What would cause a generator to go.from 8 hour run time down to 5
    Habit-Forming:
    New Friend:
  • 18 Answers
You are probably drawing more power when you get 5 hours out of it than when you get 8. It could also be that your choke is not fully off. The engine will also be more efficient if it is hot. If it is cold outside, you may want to put a box around it to keep heat in. Make sure that you leave openings for the exhaust to escape and fresh air to get in.
Posted on Dec 09, 2016
My 6000 watt portable generator will only run 5 or 6 m7nutes and then shut down?
check oil level --fuel--fuel filter--and check if overheating
Oct 27, 2016 | Lands Phones
What kind of oil do you use
Judy, Generac portable generator oil recommendations. Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.generac.com/service-support/faqs/portable-generator-faqs
http://www.generac.com/service-support/faqs/home-backup-faqs
Best oil for Generac generator Lawn Mower and Small Engine Bob Is The Oil...
Generac Generator Oil Change
Apr 18, 2016 | Generac Electrical Supplies
Power Mate 1,850 watt. What is the run time?
what is meant by the run time
an 1850 watt unit will run indefinitely if the out put is around 1750 watts but probably 5 minutes at 1850 watts as that is the max wattage for surge start ups ( electric motors switching on as in fridge compressors, drills, compressors)
if you are running it at around 900 watts constant then a tank(20 ltrs) of fuel will probably last 8 hours
Apr 08, 2016 | Electrical Supplies
What weight oil does a 5550 watt take?
According to Generac for there Portable generators they recommend, Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter. Here is a link to get a manual if you need one. You will need your model number.
http://www.generac.com/service-support/product-support-lookup
Jan 30, 2016 | Generac Electrical Supplies
Why does my generator stop working in the middle of the nights?
Hi Evans
The usual cause is lack of fuel. Most generators only run about 8 hours maximum on a half-load of electric capacity.
-Steve
May 15, 2015 | Electrical Supplies
UNIT SHUTS DOWN FREQUENTLY
How soon after starting does it shut down?
The hour meter is fed directly from the AC output off the generator stator, if there is no AC output the meter will not run. Assuming it shutdowns quickly, check 1st the oil level and make sure the low oil sender unit is ok, wire #24 to ground. If that is bad it will shut down. Check to see if you have 240V on L1 and L2 on the breaker for the brief time it does start, that will confirm stator/rotor has an output, then your problem moves from the generator portion to either the oil sender, or control board.
Feb 24, 2013 | Powermate Coleman Standby Generator...
Electrical sytem dies then returns when cooled down
Ford has a technical service bulletin out that may fit your concern.
ISSUE:
The charging system indicator may illuminate or vehicle may not start. This may be caused by a discharged battery due to a poor electrical connection at the generator terminal.
2.0L
  1. Replace generator B+ cable with a new Cable (F5RZ-14300-FA).
  2. Replace the generator B+ terminal with a new Terminal (F3RZ-10329-AB).
  3. Install new B+ cable retaining nut and tighten to 10.6 ±1.6 N-m (8 ±1 lb-ft).
2.5L
  1. Replace generator B+ cable with new Cable (F5RZ-14300-EA).
  2. If the generator B+ terminal is damaged, replace the Generator (F6RZ-10346-BB).
Jan 31, 2009 | 1996 Ford Contour
Generator shutting down after 1.5 of run time
I had the same problem with a simular generator. I took it to a repair shop who told me it was the "low oil sensor". They fixed it and it lasted another 1.5 hours. I told my-self I would monitor the oil and cut the "low oil sensor" electronic line. It has laster 12 years as a backup generator running at least 200 hours per year. I still have it but have switched to a larger generator. If you, or whoever uses it, can watch the oil level, then cut this line, it will be fine. This sensor is for those who are not able to measure oil level !!!
Sep 20, 2008 | Electrical Supplies
Electrical Supplies Logo
22 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
