Question about Electrical Supplies
What would cause generator to go from 8 hr run time down to 5
    Sergeant:
    Habit-Forming:
  • Electrical S... Expert
  • 168 Answers
Roger,
Which Generator do you have?
Posted on Dec 09, 2016
What would cause a generator to go.from 8 hour run time down to 5
You are probably drawing more power when you get 5 hours out of it than when you get 8. It could also be that your choke is not fully off. The engine will also be more efficient if it is hot. If it is cold outside, you may want to put a box around it to keep heat in. Make sure that you leave openings for the exhaust to escape and fresh air to get in.
Dec 09, 2016 | Electrical Supplies
I have a 2002 HR MOTOR HOME WITH A 7500 QUITE ONAN GENSET THAT WILL NOT RUN BOTH AIR CONDITIONERS WHAT WRONG WITH IT
What happens when you try? breaker trip? shut downs unit? what code flashes on the units start switch? Does the HVAC run ok on shore power? Does it happen when the HVAC runs turns off, then back on in less than 5 mins (high head pressure and locked rotor start current) Please give more details
Sep 05, 2014 | Electrical Supplies
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
My hr meter reads 8.0, is this 8hrs? If this is then my hr meter is wrong cause I know I haven't ran this for 8hrs.
that would be 8 hours. the hour meter measures engine run time. so if it is just started and setting in one spot, it will count on the meter. if you are sure the engine has not run anywhere near 8 hours then there could be a problem with your meter and you should contact your dealer for replacement.
May 14, 2011 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Coleman Powermate 6250 stops after 5-8 minutes of running
the carby needs to be cleaned out properly the jets blown out with air.when you intendto stop useing for any length of time swich the fuel off and let itstop by running out of gas or drain the carby before storage ,as fuel evaporates and the additives dont they build upafter a while and start to block the jets make sure motor is level,oil cutoutcan be fooled if not level ,disconectwire if worried about that bing the problem
Jul 28, 2009 | Coleman Powermate Premium Plus 6250W...
Generator set starts runing for about 1 hr and then shutdown suddenly with speed fault messege dilplayed on the protection board
I work on these every day. Its either gonna be the rotor or stater, the voltage regulator,or its a bad stepper motor which is the throttle motor, or control board. Thats all that could be causing that so its one of those. If its the rotor or stater thats bad it causes the generator to RPM up because it thinks its not producing enough power due to that then it shuts down.
Jul 11, 2009 | Electrical Supplies
Runs fast, only 5 hrs recorded on 8 hr tape. Any speed setting
check that you have the right type of tape, SRC-800's should record 8HRS with a T-160 tape.
May 08, 2009 | Sanyo SRC-800 VCR
Electrical sytem dies then returns when cooled down
Ford has a technical service bulletin out that may fit your concern.
ISSUE:
The charging system indicator may illuminate or vehicle may not start. This may be caused by a discharged battery due to a poor electrical connection at the generator terminal.
2.0L
  1. Replace generator B+ cable with a new Cable (F5RZ-14300-FA).
  2. Replace the generator B+ terminal with a new Terminal (F3RZ-10329-AB).
  3. Install new B+ cable retaining nut and tighten to 10.6 ±1.6 N-m (8 ±1 lb-ft).
2.5L
  1. Replace generator B+ cable with new Cable (F5RZ-14300-EA).
  2. If the generator B+ terminal is damaged, replace the Generator (F6RZ-10346-BB).
Jan 31, 2009 | 1996 Ford Contour
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
Electrical Supplies Logo
18 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
