Question about Kitchen Ranges
12v Spotlights flicker
I have 3 x 20w halogen spotlights powered through a 12v transformer. I have changed the bulbs to 5w LED. When they have been switched on for a while they flicker. What is the problem
    Top Expert:
  • Kitchen Ranges Master
  • 44,133 Answers
Conversion from halogen to LED lighting is not a simple plug-and-play process. The power supply is delivering more than 12v because the LEDs draw less current. The flicker could be evidence that the LEDs are gradually breaking down.
Posted on Dec 09, 2016
  • Russel Dove
    Russel Dove Dec 09, 2016
    Thanks Tom for your suggestion. I have only just fitted the new LED A/C D/C bulbs. Do you think my three spotlights require a different 12v transformer
  • Russel Dove
    Russel Dove Dec 15, 2016
    The 3 5w LED bulbs were A/c D/c and the existing transformer was not delivering enough power. Changed the transformer for the 12v 18w (3x5w bulbs) LED transformer from Maplins and the problem is now solved.
I NEED A POWER CORD CHARGER FOR THE 3,000,000 CANDLE POWER HALOGEN SPOTLIGHT. WHERE CAN I FIND ONE
If this is the usual sort of halogen spotlight, it is usually supplied with a mains charger adaptor and a lead to charge it from the car cigar lighter socket.
Both those items are also commonly supplied with a range of car-related rechargeable items, torches, jumpstarters and so forth.
I have several such items and I find the 12 volt lead and mains charging adaptor completely interchangeable between all of them. Rechargeable halogen spotlights generally have a very disappointing battery life of around 20 minutes unless a very expensive professional model is bought.
If it is not a rechargeable type that must be permanently connected to the car cigar lighter, the power cord is usually permanently fixed to the lamp but if it isn't, the cable will need to be substantial enough to carry several amps - something similar to that of perhaps a large coolbox.
Apr 11, 2017 | Camping, Backpacking & Hiking
My Sirius Range Hood has two lights that take G4 Halogen bulbs. Is there a 115V bulb made for this application or is there something that converts the voltage to 12V?
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb is just as bright but runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Nov 29, 2016 | Sirius Kitchen Ranges
How do I change the light bulb in the ASKO D3531 dishwasher?
Puzzled over this for a bit and finally pulled the dishwasher out from the cabinet. It's easy to replace the bulb from the outside. Socket is part of the wire guide which pops out with a screwdriver (see photo).
I can see threads on the inside dome but for the life of me I still can't get the dome to turn. Perhaps a special tool fitting the nubs would give one some leverage.
I replaced the 12v 5W halogen with a 12v 2.9W led assembly that has the same G4 base. Works well and should last longer than I will.
Nov 02, 2014 | Asko Dishwashers
Coleman 530 Lumens Spotlight needs a need battery FIFUTEC FP 1228, 12V 2.8Ah. Where can I find the right size?
Hi Mary, go to batteryspec.com. In the search box put in TR2.6-12 even though it's 2.6, it equates to 2.8 for our spotlights. The battery is around $20 with a 1 year warranty, and has the same specs (dimensions, terminal position) as ours.
Mar 05, 2014 | Coleman LED Rechargeable Spotlight
Bad blub where do i get another
These spotlights are, essentially, automotive headlights powered by small batteries. Accordingly, take your old bulb to an auto parts store and match it to one of the headlight bulbs they carry. You'll find many bulbs that look just about right; the key is to find one (or more) that has the exact same base as your bulb so that it'll just plug right into place.
Before buying a new bulb, you can also double-check your old bulb with a simple test for continuity. Properly treated, these bulbs have a reasonably long life, and I wouldn't rule out corrosion in the bulb socket or some other issue that's keeping your bulb from lighting up. Of course, if you can see the torn or burned out bulb filament, it's pretty obvious that you're going to need a replacement.
Jun 02, 2011 | Cyclops CYC-S250 Thor 2.5 Million Candle...
I have a 80 series landcruiser done the spotlights but thay keep blowing my head light fuse the wires are 2 times bigger than the ipf kit
The fuse has a lower AMP that is why it is blown every time you switch on the spotlights. In order for the fuse not to be blown, my suggestion is try the direct connection on the spotlights. Connect the spotlight directly to the battery. Just put a switch on it. If you want to use the spotlights, just press the switch.
Jun 26, 2010 | Cars & Trucks
Can you hook up two 12 gauge cables to the power pack of the ML 300 RTW transformer. Power cable would run in different directions. Thank you Joe
Hello yes you can the Important thing to remember here is not to exceed the wattage that the transformer puts out.
Add up the wattage of each bulb that you are running and ensure that you do not exceed 300 watts.
for example a 300 watt transformer could drive
a. 10 - 30 watt bulbs
b. 20 - 15 watt bulbs
c 75 - 4 watt bulbs
Its also ok to mix bulb wattage for example I use 10 watt bulbs in the fixtures in the front of the house but also power 4 20watt spotlights from the same transformer.
Hope that helps
Feb 26, 2010 | Malibu ML300RTW - Low Voltage Power Pack...
Kitchen Ranges Logo
610 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
