Question about Home
Intelliseat-ISB-200, water pressure in two functions became very weak, only for her back wash is normal.I cleaned nozzles and water filter without any result; please tell how to rectify this. Thanks
  • 1294 Answers
SOURCE: Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Posted on Oct 08, 2007
SOURCE: water coming from soap drawer
take back off machine, at the bottom of the drum is a very large clip slacken off and clean out fillter (looks like a bellows)
you will find a lot of muck in the filter
did this last week and its now running ok
ian
Posted on Feb 11, 2008
  • 13 Answers
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Posted on Apr 11, 2009
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
  • 4088 Answers
SOURCE: KUDS02FRSS4 low wash pressure in unit? Washes
Tear down the lower spray arm assembly to the deck while noting placement and orientation of each piece. There should be a large screen at the bottom that may be plugged with food and water deposits. Soak this screen in hot water, detergent, and white vinegar mixture. When clean, check all holes in the deck plate for any food plugging, then reassemble the entire unit in reverse order. Check all spray arms for plugging of the small holes and for any split seams. Hope this helps.
Posted on Jan 04, 2010
The water is not getting hot anymore. How can I fix this problem?
I'm not sure what exactly you're talking about here, but if it's a hot water heater, the most common problem is that one or more (most have two) of your heating elements have burned out. You'll need to get new elements for one or both of them and install them. CAUTION: Turn off the power on whatever circuit handles the water heater, get yourself a water heater element wrench (nothing else will do the job), cut the water supply to your home - all of it! Remove the defunct element(s), replace it or them, turn the water supply back on and listen - put your ear up against the tank and see if you can hear a sizzling sound. After about an hour you should have hot water again.
Jan 18, 2018 | Home
Why nozzele doesnt work
Rozana Sirine... hello,
Wind-shield washer nozzle can get clogged by putting window wash rather than windshield was in the reservoir...
Remove the washer bottle from your vehicle...
empty ...
Simply put a high pressure hose stream into the
bottle and wash it COMPLETELY CLEAN....
Put a small amount of water into the tank and
directly TEST connect the battery to the motor to
see if the pump MOTOR still works.
GENERIC Replacement parts are available at
auto-parts houses... (I am a OEM Stock-nut & must have ORIGINAL EQUIPMENT but that's just me))...
If all that works... use an ordinary sewing pin to assure the spray nozzles are open (or replace them with new ones...
Finally... My 535i BMW needed a new external SPRING at the edge of the hood to keep the washer hose from kinking ...
(radius the turn... gently)...
If all that fails to resolve your nozzle issue comment me back... we can try to better identify your "vehicle" to get into the electrical... More Information for TRICO 47100
Sep 26, 2016 | Cars & Trucks
The seat is cracked and doesn't heat anymore, is there anything I can try before buying a new one?
if the seat is cracked then the element is probably broken at the crack site
check for circuit continuity of the element or buy a new seat
can't be too hygienic or comfortable sitting on a cracked seat
Jan 20, 2016 | AMDM Intelliseat - The Ultimate Bidet...
The remote for intelliseat doesnt work, even with brand new batteries. Any ideas?
My remote worked but the blower would not respond. If that's the issue, take the label off the remote (the corner by the heater button) and put a piece of aluminum tape over the contacts so there is a better connection. I also got a new one from AMDM (under warranty then) but I am still using the first remote I fixed. AMDM customer service: 1-800-778-1450
Feb 13, 2015 | AMDM Intelliseat - The Ultimate Bidet...
The rinse "cycle" runs for an extended period of time
not sure why this is happening...do you have the manuel to see if you can adjust the cycles or times...but it sounds like the control board may be getting stuck in cycles....try and unplug for 5 minutes then see if it goes back to normal....if not try and contact the manufacter and see what they advise...good luck
Jul 08, 2014 | AMDM Intelliseat - The Ultimate Bidet...
Why can't we get the nozzle to move?
If you need a replacement part that includes a functional nozzle, you can purchase it here http://www.ebay.com/itm/Intelliseat-AMDM-ISB-200-body-Replacement-/222019823660?hash=item33b169a82c:g:v8QAAOSwzgRWvLSS
Aug 27, 2013 | AMDM Intelliseat - The Ultimate Bidet...
Amdm intelliseat isb 200 no longer works with remote how do I fix it
Look on Costco site, the manufacturer seems to have had a bad run of remote controls. Replacements can be gotten, but you have to jump through some paperwork hoops. For a DIY fix, find a clean quiet workspace and carefully peel off the front plastic overlay with the dimpled buttons. Clean the now-exposed contacts with CAIG/Cramolin Red, then preserve them with CAIG/Cramolin Blue. Carefully reinstall the overlay, and try pressing the buttons repeatedly until they start working again. If you're a klutz or slob, don't waste your time trying to do this repair, it's too difficult.
Jun 06, 2013 | Audio Players & Recorders
Home Logo
76 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
