Question about Roku Televison & Video
SETTINGS MY ROKU 1 UP TO MY T.V. - Roku Televison & Video
Starting Roku Expeess for Netflix
Hello friends...
Just follow these steps:
    1.Press the Home button to navigate to the Roku Home Menu.
    2.Select Settings.
    3.Select Netflix Settings.
    4.Select Deactivate this player from my Netflix account.
    5.Select Yes.
    6.The device is now deactivated.
    For any help visit us: www Roku Com Support
Apr 01, 2018 | Roku Televison & Video
I lost my romote to my roku and it got reset. how do i set it up again without the remote
Hello
Reset Roku without Remote:
Soft Reset
From Menus (Newer Models - 4, Premier, & Ultra)
1. From the Home screen, select "Settings" > "System" > "Power" > "System restart".
Using Button (Older Models)
1. Find the "Reset" button on the back or bottom of the device. Some models will require a paper-clip to press the button.
2. Press the button, then release after about one second. The device should reset successfully.
Power Pull If none of the above soft reset options work for you, you may need to disconnect the power cord for about 20 seconds, then plugging it back in.
Hard Reset
A hard reset will clear all settings from the device and reset it to factory defaults.
Via Menu (Newer Models - 4, Premier, & Ultra) If a soft reset doesn't fix your problem, a hard reset may be your only option. This will clear all data off the Roku and reset it to factory default settings.
From the Home screen, select the following depending on your device:
1. "Settings" > "System" > "Advanced system settings" > "Factory reset".
2. "Settings" > "Factory reset" > "Factory reset" > "Yes".
1. Remove all cables except the Power cord.
2. Press and hold the "Reset" button on the back or bottom of the device for about 20 seconds. Some models will require a paper clip to press the button.
3. Continue to hold the "Reset" button, then remove the Power cord from the back of the unit.
4. Release the "Reset" button, then plug all of the cords back into the device.
The Roku should factory reset, then walk you through the setup process again.
For any help Visit us: www Support Roku Com
Mar 21, 2018 | Roku Televison & Video
Trying to set up Netflix on my roku
Hello
2.Select Settings.
5.Select Yes. The device is now deactivated.
For any help visit us: www Roku Com Link
Mar 16, 2018 | Roku Televison & Video
MY ROKU IP # COMES UP ERROR CONNECTING TO ROKU APP
Hello
On your phone, open Settings and check your network's IP address.
    1.Go to Settings > Wi-Fi > Your network name and write down the number next to "IP Address."
    2.Your IP address will be a four-part number (e.g. 192.168.0.125).
    3.Now, check the IP address of your Roku device. For any help or support just visit us: Roku Com Link
May 21, 2017 | Roku Televison & Video
How do I correct error code 003 on a Roku?
How do I fix code 003 on my Roku?
May 14, 2014 | Televison & Video
Screen mirroring
Screen Mirroring:
The screen of your mobile device will be displayed on the tv screen this is known as Roku screen mirroring. That displays the web pages, videos and photos etc.
This feature will not support on all the Roku devices.
To use this feature your Roku and mobile device on the same wireless network.
Steps To Enable Screen Mirroring on your Roku Device:
Press Home button on your Roku remote
Select Settings-->System-->screen Mirroring-->Enable Screen Mirroring
If screen mirroring is not available in menu selection, then your Roku does not support Screen Mirroring.
If need technical guidance for Roku-related issues call this toll-free: +1-844-965-4357 and https://www.rokuactivationcode.com/
Jan 12, 2014 | Roku 3 Streaming Player 4200R
I need to ete the activation code for my roku 2 streamind device on my computer
Hello friends...
Restart your Roku device and your router to connect with Roku:
1. To restart your Roku player, go to Settings > System > System restart. To restart your Roku TV, go to Settings > System > Power > System restart.
2. To restart your router, check the instructions from your ISP or router vendor.
For any help visit us: Roku Com Link
Feb 26, 2013 | Roku 2 XD Wireless Video Streaming Device
Televison & Video Logo
55 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
