Question about Ovation Music
What is the size of wrench for ovation guitar truss rod
  • Ovation Master
  • 1,926 Answers
If an Allen wrench, should be either 3/16" or 5 mm. Both were used.
Posted on Dec 09, 2016
What size is Allen key for epiphone les paul standard pro truss rod
Frankly, if you are unsure how to adjust your truss rod, take it to your nearest guitar repairman. You can cause a lot of harm to your guitar if you do it wrong. Ask the repairman if you can watch what he does so perhaps you will be comfortable trying it yourself the next time.
Feb 12, 2014 | Epiphone Music
The neck of my guitar is not straight but i alreadyadjusted the trusrod
Edgar,
How are you determining that the neck is not straight? If you are thinking the neck is not straight because the strings are at different heights along the neck, the problem may be neck tilt or saddle and/or bridge height. You can raise or lower the bridge system or string saddles to add or subtract string height along the neck. In addition, neck tilt (particularly easy to adjust on bolt-on necks) refers to the angle that the guitar neck exits the neck pocket on the guitar body. This also effects string height.
Conversly, if you see a distict bow or bend in the neck when you look down the top edge of the neck, the truss rod may indeed be involved. Generally, most players like a little bit of "relief" in the neck. That is to say, a little bit of a concave bow. I prefer a relatively straight neck with very little relief. Just preference.
However, you mentioned you already adjusted the truss rod. Make sure the truss rod is functional. If you loosen the bolt or hex on the truss rod and the concave bow on the neck gets more pronounced, it is likely that you truss rod is ok. If you make adjustments on the bolt and there is little or no change on the neck relief, it is possible that your truss rod is not functioning or is broken. It is very possible to break a truss rod by over tightening but it would take some real effort to do. Still, it is possible.
Check out those points and see if it helps.
Confirm truss rod is working.
Check bridge height and saddle height.
See if adjusting neck tilt is possible on your model guitar.
Good luck.
Oct 17, 2013 | Fender Music
Tool to adjust truss rod
Any inbus the right size will do the job. Every respectable guitarshop should be able to tell you what that is for free. Don't even think of using anything even a little smaller: it will ruin the truss rod's head.
Feb 02, 2013 | Fender Squier Affinity Stratocaster...
Hi, I would like to adjust the rod on my Applause AE148. On the Ovation internet site it says a special tool is needed. The location of the rod inside the guitar makes it difficult to see what kind of tool...
First, get a mirror and strong flashlight and try to get a better look, maybe loosen the strings first to get better access. It is probably either an Allen key or hex head. Once you are confident you have seen it prpoerly, do something like this
http://www.ehow.com/how_5009065_adjust-neck-ovation-guitar.html
Apr 01, 2011 | Ovation Applause Series AE148 Super...
Need size of truss rod wrench. i need a manual
Takes a standard 'Allen Key' hexagonal wrench (I'm not sure of the size for your specific guitar but most are around 5 or 6mm)
Basic Epiphone manual here
http://www.epiphone.com/images/EpiOwnrsManul.pdf
Feb 17, 2011 | Epiphone AJ220SCE AcousticElectric Guitar
My celebrity deluxe was damaged a while ago. Neck separated from body. Was repaired but action(neck) not like before, strings farther from neck, harder to play. Can neck be reset with better action like...
Yes, a competent Luthier should be able to reset it... HOWEVER it may just need a truss rod adjustment. The truss rod bends the neck slightly to set string height in the middle of the neck.
Dec 21, 2010 | Ovation Celebrity Deluxe Guitar Acoustic
Buzz at the e6 string 11th fret
Have you changed strings on it? Old strings get worn spots in them from rubbing on the frets that will cause these type of symptoms. If you put new strings on and get the same issue, check your neck relief (the amount of bow in the neck) to do this, hold your low E string at the first fret, and at the 12th or 14th fret. The neck should have a slight bow in the middle that puts it between 1/16" and 1/8" or so away from your string. If it does not have enough bow in it, you can adjust the truss rod. Most guitars use an allen wrench for this, it will be inside the soundhole on an acoustic usually, and on an electric it is normally on the headstock under a cover. There are many how-to's online about adjusting a truss rod, the key is to do it very slowly, only do about a 1/2 turn a day, retune, check it again the next day. Loosen the truss rod to put more neck relief, tighten to straighten the neck. If this still doesn't fix you up, let me know, and I'll tell you where to go from there.
Apr 24, 2010 | Washburn D10sbc Acoustic Guitar
Guitar truss rod dilemma
The truss rod must be too slack then.
Is the sound ok? Does it play ok?
In it's current state the truss rod is doing nothing.
If the guitar is sounding ok and playing ok, then the next time you change the strings pull the truss rod out and throw it in the garbage.lol
Seriously though...just pull it out and put it aside.
If,however,the guitar is not sounding ok then try tightening it.
If you're unsure about how much to tighten it then I suggest taking it to your local music store for help with that.
Sep 21, 2009 | Music
No the truss rod is usually in more than that. Take it to a reliable Musice Store and they shold be able to adjust it for you.
Sep 21, 2009 | Boss Micro BR Digital Recorder
I need to know how to adjust my truss bar on my washburn d10 to make the string action bigger
Actually you can do this by adding shims under the saddle to raise the action. Then use the truss rod to make the action uniform if necessary. I try to avoid making adjustments to the neck because it could lead to undesirable perminent alteration to the neck. If you do make adjustments to the truss rod you should tune the guitar to pitch and let it sit left alone overnight to allow the wood time to adjust to the new adjustments.
Here is a link to an article on Adjusting action on an Acoustic Guitar.
Jan 24, 2009 | Washburn D10sbc Acoustic Guitar
Music Logo
266 people viewed this question
Top Ovation Music Experts
Computer Links
ray gallant
rhodesworks
Are you an Ovation Music Expert? Answer questions, earn points and help others
