  • 11 Answers
SOURCE: Agitator not working on Maytag PAV2300
Sorry to be the bearer of bad news, but the transmission in your unit is bad,it has internal gears and the ones involved in the agitation are broke or bad, to replace the transmision is a lengthy process, your best bet is to just scrap it and get a new washer. I don't know if you know this but maytag company is no longer in business. They were purchased by Whirlpool back in November of 2006. One of the reasons is all the poor quality of their appliances. I am a technician that has been doing this for 15 years. The best unit I have seen to date is the Whirlpool Duet. I hardly ever have to work on them. Sorry for the bad news. Hope this helps.
Posted on May 20, 2007
  • 61 Answers
SOURCE: the washer will spin, but will not agitate have
check splines in agitator coupler
Posted on Sep 29, 2009
  • 4088 Answers
SOURCE: Broken agitator
If the main shaft were broken, the entire agitator assembly would come out. Usually, there is a plastic adapter that goes from the shaft to the interior of the agitator and is splined to mate with the shaft. A bolt commonly holds the two together, but usually has an uncommon drive head. There may be a removable plastic cap that either unscrews or just pulls off. Hope this helps!
Posted on Jan 10, 2010
Testimonial: "Very helpful, thank you!"
  • 84 Answers
SOURCE: k'more series 70 - wont agitate or spin - makes
There is something in the pump. Probably a sock.
Posted on Jan 12, 2010
  • 8220 Answers
SOURCE: I have a WTW6300S60 washer that is just over three
Get a Roper
Posted on Feb 01, 2011
Testimonial: "I am thinking I need to get something other than a whirlpool. They seem to be great for a few years then you just pich them out. Thanks"
Maytag A512. Screeching noise smokes. Belts replaced, water pumps fine, spins. It does not agitate but the agitator is fine. Not stripped. What other problems? Transmission? parts to fix it?
The agitator shaft, not the agitator, is corroded and does not move freely.Smoke is the overheated belts, you need a transmission overhaul, boot seal and tub bearing as well as replacing the agitator shaft, again, NOT the agitator.
Jun 06, 2017 | Maytag Washing Machines
My washer shaft wobble before and after spin What may be the problem and is it fixable ?
Jun 11, 2015 | Washing Machines
Simpson ezi loader
The bearings are pre-loaded with grease but a smear of lithium grease can be used to ease fitting into the spider.The howling could be possibly because of the drum bearings.If your machine is making a rumbling noise as the drum turns then you most likely have an issue with the drum bearings. It's possible that normal use can allow water to get to the bearings. Remove the washing machine belt and manually turn the drum. If you hear a rumble as you turn the drum then problem is the ball bearings. Remove and replace them with new ones.Not knowing if your Simpson is a direct drive through a multi -speed gear box or another method, that makes it hard to give you a definitive answer. In my experience with earlier Simpson Washing machines the agitator should lift off the Splined shaft in the bowl by gripping the bottom of the agitator on the bottom edge using both hands at 180o between them, basically one opposite the other and trying to lift the agitator off vertically straight up until it clears the splined shaft and above the top lip of the bowl at which time you can remove it from the bowl. Be careful it doesn't give way suddenly as you maybe leaning over the bowl and with the force you sometimes have to exert it might come up and strike you hard around your facial region. If the agitator either has never been lifted off or a long period of time since it was then you may have to "wiggle" the agitator whilst attempting to lift the thing of the drive shaft. Once you have removed the agitator clean and re grease the splined drive shaft with suitable grease, not too much only a smear as too much will melt and leach into the bowl and hence you'll have greasy marks on the washing. Clean out the female splined section of the agitator and again a thin film of grease should be rubbed on the female splines. Replace the agitator on the shaft and make sure it's fully the length of the shaft as it will ride up and attempt to come of the drive shaft whilst the machine is operating if it's not seated correctly. If you think there are / is foreign objects beneath the agitator that seldom happens but sometimes it can with small articles. The problem of noisy agitators can be caused by worn bearings in the drive gear box which in turn allows the agitator to move sideways a bit and that then can grind on the bottom of the bowl under the agitator or even allow a small piece of cloth to get under the agitator etc. I doubt the unit would be driven by a belt directly connected to another pulley on the agitator but only a sub bowl inspection can prove that. I've never come across a Simpson that doesn't have a 2 speed direct drive gear box for the agitator and the spin dryer.
Note:- if you aren't sure about the greasing i would recommend you to contact the company's technician.
Hope this solves your problem.Please rate me if it helped you.
Apr 12, 2014 | Washing Machines
My hotpoint washer will spin but will not wash or rinse, the agitator makes a noise as it attempts to wash and then rinse. the spin seems to work fine
The agitator shaft has splines at its top which fit inside a splined area inside the agitator. Sometimes the splines in the agitator strip; then you would need a new agitator. If that is not the case the problem is within the mechanism. There is a repair kit available for that, but you need to take the mechanism out of the machine. I am assuming that you have the "direct drive" machine, recognizable by the pump sitting at the front, in the middle, under the tub. If you have the older, belt driven washer, please get back and I will explain.
May 09, 2011 | Hotpoint Washing Machines
I have a GE top loading washing machine. The agitator has stopped working and the drum no longer spins at the end of the cycle when the water drains. What can I do to fix it and get the agitator...
When the agitator on your GE washing machine does not work correctly, the most likely cause is a worn drive bell. The drive bell sits on the agitator shaft inside the agitator. The shaft and the inside of the bell lock together using splines. When the splines inside the drive bell wear out, the agitator will not rotate correctly. To repair the agitator on the GE top loading washing machine, you will need to remove the agitator and the drive bell.
1. Unplug the GE washer from the wall outlet. Open the washer lid to access the agitator.
2. Grab the bottom of the agitator with both hands and pull the agitator out of the washing machine. If the agitator will not budge, rent agitator hooks to pry the agitator out. Agitator hooks are available at appliance repair stores. Set the agitator hooks under the agitator and push down on the handle to pull the agitator off the shaft.
3. Pry off the plug on the top of the drive bell on the agitator shaft with a small flathead screwdriver. Use a socket wrench to remove the hex head bolt at the top of the drive bell. Carefully pull the drive bell up off of the agitator shaft. This may take some force depending on how stripped the inside of the drive bell has become.
4. Inspect the inside of the drive bell. There are splines inside the drive bell that line up with the splines on the shaft. Most often the splines inside the drive bell have worn, causing the shaft to spin but not the drive bell. Also inspect the notch on the outside of the drive bell and the notch inside the bottom of the agitator. If either of these are worn, replace the drive bell and the agitator.
5. Take the drive bell to an appliance repair shop to purchase a new part. If you need to replace the agitator, take the old one with you as well. Compare the new parts to the old ones, making sure they are identical.
6. Position the new drive bell over the agitator shaft, lining up the splines on the shaft with the splines on the inside of the drive bell. Set the securing bolt back into the top of the drive bell and tighten the bolt down until it pushes the drive bell down until the bell bottoms out. Push the new plug on the top of the agitator bell with the palm off your hand until the plug locks into place.
7. Place the agitator over the drive bell and slowly rotate the agitator until the notch inside the agitator lines up with the notch on the outside of the drive bell. Tap the top of the agitator down with the palm of your hand until the notch on the agitator locks down over the notch on the drive bell. The agitator will not bottom out flush with the tub.
8. Close the washer lid and plug the washer power cord back into the wall socket.
The defective agitator is the cause of the drum not spinning. So get the agitator fixed and it should solve the spinning problem.
Good luck.
Apr 22, 2011 | Washing Machines
My older 6 cycle g e super capacity heavy duty washer will not agitate or spin unless I take out most of the laundry and then it seems to work fine.... is that a belt or a clutch?
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
Jan 05, 2011 | GE Washing Machines
My agitator is not working in my washer- it is a kenmore elite. the agitator seems locked up. Everything else works fine.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Hope this helps.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
-no agitation
Welcome to Fixya
My name is Huum,
All functions operate normally except the machine will not agitate
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 10, 2008 | Maytag PAV2300 Top Load Washer
I have a Bosch frontloader. I have had it almost 4 yrs. About 6 months ago or a little longer the tub has started to bouce terribly when washing heavy clothes such as jeans, towels, bedding. I have to...
The inside of the agitator where the transmission shaft attaches can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Aug 07, 2008 | Bosch Washing Machines
Washer does not agitage the clothing. The clothing rotates in one direction within the washer tub.
Hold the inner tub and turn it bothways. if it is free in both directions you have a bad bearing. If it turns in one direction only, the bearing is good.
Your agitator has a series of interlocking teeth on the inside which lock onto the corresponding teeth of the motor shaft. If these plastic agitator teeth are worn it wont grip the drive shaft, hence, no agitation.
Jul 23, 2008 | Maytag Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
