Question about Ryobi Garden
My Ryobi electric chain saw - the plastic washer for adjustic the chain tension has disintegrated (broken). is there a replace for this.
    Top Expert:
  • Ryobi Master
  • 51,548 Answers
Perhaps if you try their website . they can answer this . https://www.ryobitools.com/power-tools/support/manuals
Posted on Dec 09, 2016
How do you adjust tension on the chain of a ryobi pole saw
Try Googling (Ryobi)(model)(manual) without parens to get instructions.
Sep 18, 2017 | Ryobi Garden
How to crank the tyobi chain saw expander and make the chain saw move
You should be able to adjust the guide bar by loosening the lock handle and adjusting the cam to push the bar out to tighten the chain, If the guide bar is at the end of its adjustment the chain is stretched and needs to be replaced, as I understand your question.
May 21, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
The chain jumps off all the time no manual supplied with it
There should be a bar adjustment screw or mechanism somewhere under the guardplate where the non-visible end of the chain is. This pushes the bar outward and tensions the chain so it is not slack and comes off.
Jan 19, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
I bought a ryobi 14 inch electric chainsaw. Is
Use regular bar/chain oil available from home centers, hardware stores, and saw shops. Always keep the chain properly sharpened and tensioned so that you don't have to force the chain into the cut which causes motor overheating. If you need to make an 'under' cut, do so with the top of the bar--don't run the saw upside down. Good luck!
Jul 30, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Were can i buy a tension adjustment screw for a rcs4046c chain saw
Hello. Look in the yellow pages under chain saws. Any chain saw shop that sells Ryobi chain saws will have these screws in stock or be able to order one for you. Joe
please rate my answer as very helpful. Thanks
Apr 18, 2010 | Garden
Chain saw brake does not go off
Your switch is broken and needs to be replaced. You can do it yourself when you get the part from a Ryobi dealer.
Jan 16, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Fix the tension tightener for ryobi chainsaw
the nut like end of the tention bolt should fit into a hole in the bar. Then as you unscrew the bolt later one it ill push the bar farther away from the bolt heal thus tightening the chain
May 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
80 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
