Question about Ovens
Can anyone tell me what ---C means on a Prima oven please?
How do i cleaning inside oven glass door on a prima prs0102 oven
The glass panel is a sealed double pane. Caning is not recommended.
Jan 14, 2017 | Ovens
RECEIVING A F2 ERROR CODE ON DISPLAY SCREEN. CAN ANYONE TELL ME WHAT THE CODE MEANS AND HOW TO FIX THE PROBLEM?
the oven has had a high temp the temp sensor will need to be replaced , cost about $75 but if you look around you can find it for much less
Apr 25, 2010 | Maytag CWE4800A Electric Single Oven
The bottom oven isnt working its a prima oven and has the fault F 03 on it , cant find the manual so not sure what code means
F-03 code is a defective temperature sensor.
It is inside the oven on the back wall up high. A thin piece of metal about 3 inches long.
It should unscrew and be removed from inside the oven. A volt meter set for ohms should read 1100 +/- 50 ohms. If more or less ohms replace the sensor.
Dec 20, 2009 | Ovens
Unable to start the oven prima lpr9023
Hi i have just fitted my new prima double oven Type FCSM9 Model LPR 9030 and the main oven will not work, and i can not set the clock. it came without instructions. can you please help
Nov 10, 2009 | Ovens
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
Feb 22, 2009 | Stoves 720EF Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
