Question about Konica Minolta Office Equipment & Supplies
Plzz help me konica minolta bizhub 195 error code M2
I change developer
    Top Expert:
  • Konica Minolta Master
  • 8,204 Answers
See if this link helps you out... konica minolta bizhub 195 error code M2 Google Search
Posted on Dec 09, 2016
Testimonial: "CHANGE YOUR DRUM UNIT OR DEVELOPER"
No drum replace & developed replace how to sole konica minolta bizhub 206 error code m2 reset
did you clear the counters for the drum and developer FIRST if not get a new drum and new developer as both are replaced at the same time. As the machine uses the counters to determine a a new unit and adjust certain voltages to certain units accordingly. Other wise machine thinks it is old when it is new and causes image issues and codes
Apr 23, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 195 shows M2 error after changing the developer how to reset M2 error?
Did you also replace the drum, clear the developer counter first before installing the developer, and run the required F 8 procedure after the developer was installed, As the machine uses the counter to control voltages to certain assemblies, not replacing the parts and resetting the counter will cause codes and image issues.
Jan 19, 2016 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
Fix a xerox 6350DT
If you have a white stripe in only one color, then you might have a bad developer. Each color has its own developer
116-2008-00 Yellow
116-2009-00 Magenta
116-2010-00 Cyan
116-2011-00 Black
Changing the developer is not super easy. You'd have to remove the left cover, HV Power Supply board, then remove Image Unit and the Developer Frame, where all the Developers are mounted. Detach the feed hose for the Developer you want to change and release the Developer's 2 spring clips.
The attached photo shows old developers which have dead spots that would cause the missing stripes on prints.
Sep 12, 2014 | Xerox Phaser Office Equipment & Supplies
BIZHUB 164 error M2 what have I to do
Replace the developer and the drum make sure counters are cleared first and that Gradation adj is run along with Toner adj
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
replace the drum and developer and then reset the counter
Xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 776
When you have a sensor failure, you need to replace the black ATC sensor and recalibrate it. Another reason for sensor failure is you are not getting toner moved down to mix with the developer...the toner tube/auger spring could be clogged up or not functioning.
Also if you changed the developer housing when you changed the developer, you need to change the value to the new sensor # that comes with the housing.
Feb 16, 2014 | Xerox Phaser 7760DN Laser Printer
Reset error m2 in konica minolta 164
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes.
Jan 13, 2014 | Minolta bizhub 180 Black and White Copier
100 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
