Question about Sharp Televison & Video
Rain water got into 36inch Sharp CRT TV while carrying it to and from car, how long should I wait until its dry?
  • AEANEA Dec 09, 2016
    Went to turn it on and it made an abnormal electrical sound, so we turned it off immediately and unplugged it. Worried about fire hazard.
    Friends moved it for me. I would have covered it -_- You would think they would have thought of that considering it has been raining on and off for two days -_-
    Top Expert:
  • Sharp Master
  • 52,123 Answers
Guess that is why they invented plastic . it may never dry out , a repair shop would be a worth while trip
Posted on Dec 09, 2016
2 Suggested Answers
gopakumarg43
  • 75581 Answers
SOURCE: sharp 14" crt tv model598WJ
What is the problem with your Sharp TV? Provide more details please.
Posted on Sep 29, 2012
Our water pressure in our house is gone. we have a well. do you think the well is out of water? do we just need to wait till it rains?
If you did manage to run enough water to dry the well, it should only be temporary, until enough groundwater flows back to your well. This should only take maybe an hour and shouldn't depend on frequent rain. If your well did respond to rain, your well would be quickly contaminated. However, there could be other problems. If you have the type of well where the pump is located down in the ground, and your water pressure doesn't come back soon, then you have a problem in that the pump is not working. If you have a "shallow well" type of pump, where the pump is located above ground (in your basement, or under the house) then the pump may have lost it's prime. A shallow-well pump needs the pump to be full of water before it can pump the water from the well.
Jul 30, 2010 | Plumbing
Sharp tv ...want to use Rca remote D770 how do I program the remote?
Press and hold the device button you want to program (TV). Then type in one of the codes for Sharp TV's:
1004, 1006, 1012, 1029, 1095
1111, 1112, 1113, 1122, 1171, 1173
Release the TV button and press the on-off button. If that doesn't work, press the device button and try the on-off button again. Continue trying codes until one works.
Another thing to try: Turn on device. Press and hold the button for device you want to program, press the on/off button and hold until the LED turns on, and then release both buttons. Then, point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing. If the device does not turn off, then continue to press play and wait the required interval (for a maximum of 20 times) until the device turns off. When the device turns off, stop pressing play. Press REVERSE, wait two seconds and continue doing this until the device turns back on. To finish programming, press and hold STOP until the LED turns off.
If neither of these methods work, the remote probably isn't compatible with your TV (manufacturing dates matter; newer tv's often don't work with older universal remotes). In that case, try remotes.com for a exact duplicate of your TV's original remote. http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=19C140&uuid=12795625009490
I hope this helps.
Jul 19, 2010 | Sharp 19C140 19" TV
I have a gold gemstar/rca 36inch tv and I can't
to enter the codes u must use yhe orig. remote
May 22, 2010 | RCA F25432 25" TV
My tv just blanked off and want come back on its a sony trintron 36inch color tv
do you have any audio? if you do the it's usually a fuse for the video circuit. if no sound no picture, then main fuse power supply out
Sep 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Screens nturns black but have audio
Ur video board is dead.Or the video socket connect to the CRT(tv tube) is cold solder.
Sep 06, 2009 | Sony KV-27V40 27" TV
98 saturn sl2 horn is constantly blowing.
You may just have to wait it out until the shorted out areas dry out, or disconnect the battery cables, replace the fuse, reconnect the cables and see what happens. HOWEVER: If you do, you will also reset everything else electrical. . .
Nov 15, 2017 | Saturn SL2 Cars & Trucks
My television has a very dark screen because of rain water
I'm assuming you unplugged it and let it dry out?
First I would check the 180v supply to the video outputs, if missing, check the source off the flyback transformer, usually through a low value resistor, check the supply diode for no shorts.
Jun 27, 2009 | JVC AV-32F475 32" TV
Sharp 25" tv unknown model (no av in)
It is a simple trouble, tv has got dry solder joints in the vertical deflection circuit. Resolder vertical output ic pins and related components, this will be okay.
Dec 17, 2007 | Sharp 25R-S100 25" TV
My Television makes a weird noise.
hi....maybe theres a problem with your high voltage(flyback)section.or maybe there are still moist inside your tv...try to open it(if you can) and use your hair dryer to dry it....if noise still present after you done it....call the serviceman
Apr 24, 2007 | RCA F36668 36" TV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
