SOURCE: My car AMP will play for a few minutes, then just Turn OFF
Is your sub single voice coil or dual? If it's dual, is it wired in paralel or series? It's possible for an amp the heat up so fast, the outside is not hot to the touch. Also, the next time it happens, use a paperclip and short the 12+ to the remote wire on the amp and see if it comes on. Let me know, and be sure to leave feedback or I don't get paid
SOURCE: mtx 1501d no sound
There are a number of things that can cause it to act as you described. Have you pulled the covers off of it yet to see if you can see any problems?
If you do, disconnect power from it and don't touch ANYTHING on the board when ANY of the 3 LEDs (2 are not visible from the outside) are lit.
SOURCE: red light comes on and amp quits working
it is shutting down to protect it self.you either have a short in your wiring or your speakers are wired at an ohm that the amp can not handle.mke sure that they are not wired wrong like + to - is it getting hot?
SOURCE: sony xplod 1000 watt amp not working
you need a amp kit your battery or alltinator isn't powerful enough to handle the wattage you need a juice can it gives yur battery more power
