Riso tr 1510 error e006 - Office Equipment & Supplies
Riso EZ 570 e "T12-301" error. What is this error
check master disposal box. take it out and check for jams
Nov 01, 2011 | Riso RZ220 Duplicator
ERROR CODE T04-513 FOR RISO RP 3790
riso rp 3790 no imprime, no copia, me dijeron que borrara errores pero no se donde, creen que sea eso
Feb 27, 2010 | Riso Office Equipment & Supplies
E006-002 error
...error code E006-002...there's a broken connection between the machine and the fixing unit as the front door is close...try to see the wiring from the fixing unit to the machine...or see the wiring in the fixing unit...
Jul 09, 2009 | Canon Office Equipment & Supplies
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Got error code e104 duplo DP-460H
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Jan 08, 2009 | Duplo DP460H Copier
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
Troubleshooting
Your problem is with you clamping unit which is responsible for put the master on to the drum. Please check the unit for any phycial damage. You can also remove the old master on the drum your self and place back the drum into the machine and try asking the machine to make a new master. Good luck.
Donny Swann
Jun 12, 2008 | Riso RZ220 Duplicator
jasbo
jasbo
