Question about Sewing Machines
I changed broken needle but accidently both of them came out now the left needle does not stay in
  • Sewing Machines Master
  • 11,493 Answers
Assuming this is a serger? Is there only one needle set-screw on the machine or one set-screw for each needle? If there are two set-screws, then you may have accidentally lost the set-screw for the other needle. If there is only one set-screw, both needles will need to be installed at the same time, hold them all the way up and simultaneously tighten the set-screw.
How To Change The Needle on the Brother Serger 1034d 4 Thread 2 Needle... (this machine has only one set-screw for both needles)
Some other machines, ie Bernina, have a set-screw for each needle.
Posted on Dec 09, 2016
When trying to use the zipper foot the needle will not stay positioned to the side and keeps returning to center hitting the center of the zipper foot and machine stops
set the machine to straight stitching which should keep the needle in the center position
a zipper foot is a normal foot with 1/2 missing
It it still wanders , take it in for a service
Dec 31, 2015 | Sewing Machines
How to change the needle position?
Google your machine make and model with Users Manual.
San Diego, CA
Embroidery Services
Oct 23, 2014 | Sewing Machines
How to fix a broken Needle clamp on viking 936
I don't know of a way to repair the needle clamp. It will more than likely have to be replaced. The local authorized husqvarna viking dealer should be able to service the machine. You can find the nearest dealer from husqvarna viking website -
Apr 24, 2014 | Husqvarna Huskylock Computerized 936
Bernina 1230 won't change needle position or zigzag
Most likely problem is that the machine needs a good cleaning and lubrication. You can try gently heating the needle clamp with a hair dryer (don't melt the plastic! Bernina thinks it's worth a fortune!), or run the machine full tilt with the needle out in 15 minute sessions, but usually the cure is a proper professional cleaning and lubrication. If they can give your machine back the next day, they probably didn't do a really good cleaning. See:
Feb 20, 2014 | Bernina Sewing Machines
How to change plate needles?
You are talking about a serger / overlocker ?? Yes, needles are glued in. If you get a grip on what is left(eg with long nose pliers) and carefully lift, it should come out.
Jul 26, 2013 | Bernina Sewing Machines
I have a white superlock 534- I recently broke a needle and now I cannot load two needles. After unscrewing the screw- I try to load two needles and only the right will stay in--left falling out. If I load...
I have a White Superlock 534,the needle broke and I tried to change the needle and lost the screw,it is so tiny I cant find it,is their any way I can buy the same tiny screw.I like to have 2 needles.
May 29, 2011 | White Sewing Superlock 1934D Mechanical...
I have a Singer #7430 hardly used, but I thought the needle should be changed as it sounded dull, now i cannot get the needle to stay in when i start sewing the needle falls out and i have broken 3...
some needle clamp screws have a indention where a screwdriver can be put in to turn the screw,,
check to see if your has the indention & if not you need a new needle clamp screw
Nov 04, 2010 | Singer 7430 Sewing Machine
My machine is about 20 years old but in very good condition, i have never had trouble with tension untill about a month ago, but now i cant seem to rectify it i have broken a few needles trying to sort it,...
It sounds to me like something may have been accidently changed. Double check bobbin is clean and in correct position. Also see if there is a thread caught in one of the tension guides, by pulling a thread carefully through the machine towards the needle.
Rather than breaking needles, test the tension by putting foot down and pulling on thread by hand , if its too easy to pull through something is causing the tension to be too loose
Sep 14, 2010 | Riccar R1570 Mechanical Sewing Machine
My needle keeps hitting the throatplate, (I have broken 2). It was working fine. I don't know what I have done to cause this! e.
First, check the position of your needle.Machines with zigzag capability allow you to adjust the position of your needle left, right,or center. If your needle is not in the correct position, it may be hitting your needle plate. If that doesn't work,change your needle plate.
If you've been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
I hope this helps.
Mar 22, 2010 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
