Question about Gaggia Coffee Makers & Espresso Machines
Come togliere il calcare Gaggia Syncrony Logic
JohnnyBeans
  • 223 Answers
SOURCE: Gaggia Syncrony no longer rinses during the selftest
Rinse option is in the menu. Click on Rinsing and turn it on.
That should be it.
Saeco and Gaggia Service Center
Coffee Beans, Espresso Machines, and Cleaning Supplies
www.cerinicoffee.com
Posted on Nov 23, 2007
  • 109 Answers
SOURCE: gaggia syncrony manual
http://www.partsguru.com/GaggiaSyncronyCompactDigitalEspresso.html
Have a look at this site it should have what you need.
Posted on Jan 31, 2008
EsWorld
  • 1618 Answers
SOURCE: GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Posted on Jun 09, 2009
  • 352 Answers
SOURCE: I have a gaggia syncrony logic.The coffee beans
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Posted on Dec 01, 2009
SOURCE: No power to Gaggia Syncrony Logic
Re the Gaggia no power problem, the machine does have a re set button, 2 in fact the boiler unit must be removed and the two reset switches are between the sender units (brown in colour).
After disconecting the power source open the machine (top off)The three alan head screws that retain the boiler (front of the machine) unit must be removed it can be lifted clear to gain access to the bottom of the unit where the reset buttons are.
This will save hundreds of dollars in shipping and service fees.
DIY takes about 10-20 min well worth it.
Take care when doing this opperation 240 volts can kill.
Posted on Feb 12, 2010
Gaggia Syncrony Logic has no power
Check the 2 thermal cutouts located on the side of the boiler
Press to reset
Jan 02, 2013 | Gaggia Syncrony Logic 74884 Espresso...
I have a gaggia syncrony logic that has just come back from the repairers.! The coffee dregs are almost liquid whereas before they were solid patties & liquid is found in the drip tray after every...
The coffee grind could be too fine and or not enough coffee is being added to the brew chamber after the machine grinds it. You can try to adjust the amount of coffee being used for an espresso and or adjust the grind.
May 20, 2011 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Need new gasket for boiler for syncrony logic
You can check with wholelattelove or servicesunlimited.
Oct 20, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Where to find a dispenser holder for Gaggia Syncrony logic
Need also to find height adjustable coffee dispenser, also need measuring scoop,brush and coffee dispenser with wrench.
Apr 25, 2008 | Gaggia Syncrony Logic 74884 Espresso...
Coffee Makers & Espresso Machines Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
