Question about Dometic Refrigerators
Unable to relight Dometic fridge after changing gas bottle
    Top Expert:
  • Dometic Master
  • 8,688 Answers
Possible loose line to bottle
Posted on Mar 27, 2018
  • 93 Answers
SOURCE: Start my fridge on gas
have you ever used it on gas normally theese frige have a glow coil to ignited the pilot is it a fridge in a trailer or in a house also the themocople may me defective not generating electricity i woul need more info thanks from gilles
Posted on Mar 15, 2009
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
  • 127 Answers
SOURCE: I left my Dometic RM2500 fridge in the gas postion
Check the batteries in the coach for OK. If you left the fridge on for that long without being plugged in, your batteries have drained down. If the batteries are OK, check the fuse in the control board mounted on the back of the fridge. If you have no lights, then you definitely have a 12V problem!!
Hope this helps,
Jeff
Posted on Jul 05, 2009
  • 4 Answers
SOURCE: dometic rm2652 frige just stopped working, gas nor
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
Posted on Aug 23, 2009
  • 332 Answers
SOURCE: Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Posted on Mar 08, 2010
Can a dometic RF 60 absorbsion fridge be used in a camper van if gas is not connected?
google search shows that it is a 3 way fridge --12v/ mains /gas
it will operate off the battery, mains plug in ,or from a gas bottle
so --yes it will operate without a gas connection
it is not suitable for a built in application but is stand alone unit
Jan 15, 2017 | Dometic Refrigerators
Our refrigerator works on AC. When switched to lp gas it sometimes come on and works and then goes off. Then we can't get it to work again. Then it will work if we turn on the hot water hea
It seems like a gas pressure problem. Possible blockage or kinked pipe or faulty regulator on the gas bottle. If the fridge runs ok only when you use the gas hot water, that would change the gas flow / pressure. LP gas products are normally around 1.5 to 2.75 kpa pressure. If you have access to a manometer, the gas pressure can be checked. (NB/ You should hold a gas service licence to do this)
Sep 29, 2014 | Dometic RM2852 Refrigerator
I have a dometic fridge model number 8551 and when the gas bottle ran out I changed the gas bottle over and now it won't restart on gas I have cleared the pipes turned the 240 volt off and 12 volt and
check the regulator on top of the bottle ,try lifting the bottle by the regulator to see if the valve is secure on the bottle then if it appears so take the pipe off and see if you have gas coming out ,and if you still cannot get it to work and touring here in spain well iam in alicante call in and will kick it into touch for you .
Dec 25, 2012 | Refrigerators
Dometic Fridge 2652 will not stay lit or relight in gas mode
check house batteries needs 12 volts to control board
Jul 13, 2012 | Dometic RM2652 Refrigerator
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Gas side of fridge works perfect all day, stops during night!
Sounds like you have some blockage issues and the venturi tube and pilot may need a more complete cleaning. It's possible that the supply pipes have rusted enough on the inside that you're getting small rust particles in the gas and thus into the fridge. You may have to replace the supply lines to resolve this, but...
...rather than 2nd guess what's happening, here's the a link to the diagnostic service manual for your model. You may have to enter in a code to access it once on the website, but this manual will help you troubleshoot your fridge like a pro.
http://gasrefrigeration.net/dom_techdata/7030_7732SM.PDF
Hope this helps and you solve the problem. Best regards!
Jul 06, 2009 | Dometic RM2193 Compact Refrigerator With...
I left my Dometic RM2500 fridge in the gas postion for two weeks ( Ishut off the gas at the bottle instead of switching the fridge off),now the light won't come on to light.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic Refrigerators
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Ron;
Jerry
Mar 30, 2009 | Dometic RM2620 Refrigerator
Will not stay lit
May have air in the line, bottle may be low or fridge is selecting other source of power that may be available, if a/c is online, fridge will select it as priority over lpg
Nov 05, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
