Question about Hilti Drills
HOW DO I REMOVE THE SDS CHUCK ON A HILTI TE10 PLEASE. CAN I STILL GET THE MANUAL
meleemore
  • 19 Answers
SOURCE: sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
Posted on May 05, 2009
  • 112 Answers
SOURCE: How do I remove an SDS bit stuck in a B&D SDS
the rubber cap in the sds chuck nose is only snap tight try to remove and dismantle the retractable locking pins.
Posted on Nov 29, 2009
  • 123 Answers
SOURCE: how to replace the chuck on a hilti te10
The complete chuck is not easily replaced. It you stick an SDS+ bit in the chuck and it seems to fit tight without much wiggle then the chuck can be replaced without taking the tool apart. The rubber cap on the end will just pull off. Next the locking collar with the annular spring will come off with the out side sleeve. Underneath is the guide tube with two enlongated rollers. The locking collar should have a ball bearing underneath it that locks the sleeve in place. Usually the roller bearings or ball bearing are missing.
Posted on Apr 03, 2010
rowdy45176
  • 2176 Answers
SOURCE: where to buy a hilti 36v ni-cd battery and charger
call them direct at 1-800-879-8000 and they can find you a dealer close to your area or you can buy direct.
Posted on Apr 25, 2010
HansPP
  • 2510 Answers
SOURCE: how do I remove the
The SDS chuck is an intergral part ot the rotary hammer drill assembly. You can get a standard chuck that has an SDS fitting on it and that will fit into your drill and give you standard drilling capabilities.
Posted on Mar 07, 2011
Jcb sds chuck repair
Allways In a bench vise not allways a demolition hammer has a chuck but most times a locking sleeve for sds but allways you can remove it .
Apr 30, 2014 | Hammering
I need a new chuck and rubber covers for hilti te10
you can go to hilti.com or call them direct at 1-879-8000 for the correct parts. Their customer service is excellent. Let me know if you need more assistance.
Dec 10, 2011 | Hilti Drills
How do I remove the sds chuck to fit the standaed chuck
Mar 07, 2011 | Makita Garden
To install a driil bit?
Pull back on chuck u have to use sds type bit turn it till you feel it click in
Feb 15, 2011 | Hilti TE 70 Hammer Drill Performance...
My hilti te-75 drills but is not hammering or will not go into chisel mode whay coud be the problem with it
Have seen this problem with some 'none' HILTI bits which do not fit correctly into the SDS chuck.
Tends to be with larger drill bits which have a wider shank than the SDS connector, the wider shank hits the end of the drill nose which stops the end of the drill bit contacting with the internal hammer.
Solution is to purchase original bits from Hilti. If you have OEM bits and chisel it will be another problem. Hope this helps.
Feb 07, 2011 | Hilti TE 70 Hammer Drill Performance...
'Whats the difference between a te c3x bit and a sds bit'
The difference is the type of shaft on the bit so that it matches to the chuck type of the drill...They are NOT interchangeable!!!!
You need to know which type of check your drill has and order accorndingly...
heatman101
Aug 25, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Where to buy a hilti 36v ni-cd battery and charger for a te10 codless sds drill my old one say its a 36v ni-cd-akku 1.4ah
Apr 23, 2010 | Drills
How to replace the chuck on a hilti te10
Mar 14, 2010 | Hilti Drills
Nov 26, 2009 | Drills
Drills Logo
203 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
