Question about Tools & Hardware - Others
I have a Wolf 5573 belt sander, just acquired, does anyone know if the rear roller needs to have a rubber sleave
efs_perpends
  • 1996 Answers
SOURCE: BROKEN RUBBER BELT FOR BELT SANDER
Maybe you can use a linked belt to replace it. Check the width of the old drive belt, and give these folks a call: Lee Valley
Posted on Apr 02, 2009
buffalonyman
  • 1865 Answers
SOURCE: HOW TO CHANGE THE BELT ON A BELT SANDER
There is a lever on the side of the unit, flip the lever and then slid the belt off.
Posted on Jun 13, 2009
  • 32 Answers
SOURCE: The rubber footings for a Makita finishing sander 9035N
I have my fathers old Sears sander and tools. Rubber has gone past shelf life as you stated, tried rubber rejuvenator,did not work. Value is that they were my fathers and would love for them to work, but decided to keep them on the shelf and keep the memmory, thanks for the sentimental memmory part, wish I could have helped more, yea for you!!
Posted on Jul 18, 2009
SOURCE: looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Posted on Nov 24, 2009
SOURCE: need belt for black and decker sander 110 xl 031
The belt from Jason 110XL031 is Identical in size and apperance.
Posted on May 12, 2011
Makita 9910
I think you'll need to replace the roller.
Aug 06, 2014 | Makita 3 x 24" Belt Sander
1632 open end belt sander where should the platter bar be located in relationship to the belt rollers
I have a delta sander sa180 that won't turn when the switch is turn on. The motor hums but won't turn.
Feb 06, 2014 | Powermatic Model 1632 Open End Belt Sander
How do you change the belt
The front roller (usually a metal cylinder) is spring loaded. The rear roller (usually a rubber cylinder) is fixed and is driven by a belt from the motor. You need to push the front roller against a fixed object (like a benchtop) pretty hard to compress the spring about 1/2 inch. It should "catch" in the compressed position. Belt will now be loose and easy to reeplace. Then, to "un-catch" it, on most models, just stick a screwdriver behind the front roller bracket and pry it forward. It should pop right back into place. Good luck.
Oct 13, 2012 | Black & Decker BR300 3''x18'' Belt Sander
Motor runs, but the belt doesn't turn. Is this an easy fix or is it time to get a new sander?
depending on the model there might be a problem with a rubber belt from the motor to the rear roller or the gears are damaged, if you provide that I can look at a breakdown and try and come up with some numbers for you. Let me know
Mar 05, 2011 | Craftsman 3 x 21" Variable Speed Belt...
How do you replace he belt on a 7447 Sander
To change belt:
1) Put front roller on floor and push down until roller locks back.
2) Put on new sand paper.
3) Loosen tracking screw until front roller is released.
4) With sander running, use tracking screw to center belt.
Oct 10, 2010 | Black & Decker BR300 3''x18'' Belt Sander
How do you replace the drive belt on a Porter Cable Belt Sander
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
May 28, 2009 | Porter Cable 361 3" X 24" Sander
Craftsman 3x21 plastic front roller needs replacing
Do you know anyone with a metal lathe or that works in a machine shop? If you do ask them if they can make the rollers for you out of metal. Or else find a machine shop and ask them to make you new rollers.
Apr 01, 2009 | Tools & Hardware - Others
Belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Mar 18, 2009 | Black & Decker Tools & Hardware - Others
Slipping belt
OK the belt tensioning mechanism is spring loaded. First what is the quality of the belts are they real flimsy or stiff. You say the rollers spin but my question does the rear roller still spin and the belt remain stationary. If so the rubber belt on motor is bad. I would take a look for excessive wear on the rear roller. Does the yoke mechanism snap forward or move slowly, look for a build up of sawdust in this area that might be restricting movement on the yoke. The wear plate in still good condition. One other thing on the belts are they directional? Do they have an arrow on the inside if so that has to point toward front of tool. I looked at a breakdown and could not see anything else to suggest. I never had this problem except with belts when I was at Makita.
Jan 18, 2009 | Makita 3 x 24" Belt Sander
Tools & Hardware - Others Logo
103 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
