Question about Canon ImageRunner 3570 | IR3570 |
3570 cannon copier error code 0225 001 salution
SOURCE: Canon Image Runner 3570 Error Code Display E000019-0000
Canon Image Runner 3570 Error Code Display E000024-0001
Copier ask me to shutdown machine.Its going read for funtion  and after print 0ne copy,its repet error code display E000024-0001.What is this ?
Posted on Jan 23, 2008
  • 11 Answers
SOURCE: Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Posted on Oct 01, 2008
  • 6 Answers
SOURCE: getting the ip address of a cannon imagerunner 3570 copier
first check your m/c having fiery ( Network Card )
then go to additional features function
you have to set ip address like 192.168.36.10
then configured with your pc
restart m/c
your pc in network connection click on view workgroup
you will see a new group
double click on it to install your pc
Posted on Mar 04, 2009
Daniel S
  • 4323 Answers
SOURCE: error code E 020 0181 How do I clear error
Hi
Error code E 020 0181 means that the patch sensor has turned bad or is dirty, to access this try removing eac dev unit and gently unscrew each top so that the patch sensor window is visible. Also, check whether the toner hopper is overfull, it happens sometimes that the toner motor worm gear splits as a result of the hopper becoming packed tight. This may cause the worm gear to split and break if the hopper is 1/2 full or less. You may need to replace toner motor, part number (FH7-1762-030). If the toner motor is fine, then check whether the web solenoid is activating. Clean the web solenoid and ensure free action. This would clear error E020. If the error still not disappears then make sure that the DC controller is fine and the connections from the controller are fine.
Hope this helps...
Daniel
Posted on Oct 11, 2010
  • 79 Answers
SOURCE: where can i find the
The waste toner is located on the front of the machine. You first want to lower the cover that allows you to insert the toner, then locate two rather large, silver screws that connect that front cover assembly to the copier. After removing the two screws, the toner bottle will be exposed.
If you need any further assistance, please let me know.
David R.
Posted on Dec 11, 2010
How to remove error code E000732-0001
E732 Reader communication error
0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the
reader power supply
Sep 16, 2011 | Canon imageRUNNER 3570 Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Where can i find the waste toner in on this machine cannon ir 3570 copier
David R.
Dec 10, 2010 | Canon imageRUNNER 3570 Copier
Canon IR3570 Factory reset
how to reset cannon ir 3570 photo copier
Apr 07, 2010 | Canon Office Equipment & Supplies
Getting the ip address of a cannon imagerunner 3570 copier
restart m/c
Feb 20, 2009 | Canon Office Equipment & Supplies
E000007-0000
this code is for damaged fixing film, on the end you have home position sensor for good position of fixing film.
Feb 04, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Canon Imagerunner 3570 error code
if u r still having this problem with the imagerunner 3570 u can try this:
press * 2&8 together then * again
go to function
then to clear
select eroor then ok that should take care of ur issue
Jun 08, 2008 | Canon ImageRUNNER 3570 Copier/Printer
Canon ImageRunner 3570 | IR3570 | Logo
24 people viewed this question
old marine
old marine
