Question about Kyocera Copystar CS-2560 Black and White Copier
How can i clear error code C2200 IN Kyocera machine 2560 without changing drum unit
Urgent answer needed
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 194 Answers
Something is preventing drum from turning
Posted on Oct 03, 2017
Testimonial: "your bright just keep it bro but also i have realized that the cause of that drum unit not be rotating might be the taking of long of doing thoghly service but i happened i just changed the drum unit housin"
  • 40 Answers
SOURCE: Kyocera 1810 drum replacement
If you have some mechanical skills and a steady hand you can change the drum. However it worth the money to pay a "pro"to do it. Also you may want to replace the cleaning blade too.
1. Open the front cover - where the toner is.
2. Remove the black cover - 2 screws
3. Remove a little stopper at the bottom of the drum unit + 1 screw
4. Disconnect the drum unit cable.
5. Take off 2 screws which secure the Drum Unit.
6. On top of the Drum unit you should see 2 white plastic stoppers - front and back side ends - You have to push them inside to keep the cleanng blade away from the drum.
7. Remove the MCH assembley - 1 screw.
8. Remove the front separation claws + plate - 2 screws.
9. Remove the Drum Shaft
10. Replace the Drum
There are few details about how to manipulate a Drum - Do not touch the surface, do not expose it to intense light...
8.
Posted on Jan 12, 2009
xptareq2000
  • 1447 Answers
SOURCE: change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Posted on Aug 27, 2009
  • 26 Answers
SOURCE: error code C0F37 on Kyocera mita KM-C1530
This code is not documented, the firmware must be reloaded and a service tech can only do it ...
Posted on Feb 21, 2009
  • 713 Answers
SOURCE: error c6000 kyocera km-2560
THERES A PRINTER OR A PAPPER JAM GET AIR IN CAN BLOW OUT IF CARDLIDGE REPLACE WITH NEW.
Posted on Feb 15, 2011
  • 29 Answers
SOURCE: Kyocera km-2560 c6400 zero cross
To reset this error hit 10871087 this will put the unit in Maint. Mode. Then press 906 then press start.Execute will appear on the screen press it. Either the machine will turn off by itself or it will say on the screen to turn the unit off then on using the power switch on the side of the unit. If the code comes back after all this either the fixing unit or the power supply are bad.
Hope this helps.
Posted on Jul 14, 2011
HOW CLEARING ERROR CODE C0180 IN KYOCERA 2560
Hello!
Please kindly check: here is the "Troubleshooting" part to the manual to this device.
Hope it will help!
https://manualsbrain.com/en/manuals/1173852/?page=107
Dec 07, 2017 | Kyocera Office Equipment & Supplies
saya your main pcb does not match the original main pcb number
Jul 09, 2017 | Kyocera Office Equipment & Supplies
HOW DO YOU CLEAR ERROR CODE C5300 IN A KYOCERA 5050 MACHINE
You will need to replace the cleaning lamp for the drum unit or replace the engine board
Dec 16, 2014 | Kyocera Mita Office Equipment & Supplies
The cleaning lamp (which is in the drum unit) is defective. Replace the drum unit.
My photocopier km 3060 displays error code c0120.what is the problem and the solution
Hi
I have found a list of error codes at the link below and your code is described as;
Drum EEPROM error Reading from or writing to EEPROM cannot be performed. Poor contact in the connector terminals. Defective drum unit. Error Codes Kyocera Mita KM3060
It looks therefore like a drum unit problem which probably requires a replacement drum unless you can check and improve the contacts in the connector terminals.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Oct 17, 2014 | Kyocera Km 3060 Digital Copier With...
Solution of error code 7410 for kyocera mita 5035
When Your Kyocera Mita KM 5035 Indicates Code 7410, It's the problem with your Drum Unit Or Drum. You Can Solve This Problem Either By Changing If You Have Another Drum Or Buy A New Drum Unit.
May 23, 2012 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
What is code error c0640 on kyocera km-2560
Corrupted data. clear the all the jobs from the que. restart the machine and this will fix. if not means bad hard drive.
Feb 11, 2012 | Kyocera Office Equipment & Supplies
Kyocera km-2560 c6400 zero cross signal error
Hope this helps.
Jun 27, 2011 | Kyocera Copystar CS-2560 Black and White...
I have Kyocera km-2050 it coming error for call for services error code -C6400
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Dec 05, 2010 | Kyocera CS-2550 Black and White Copier
Kyocera Copystar CS-2560 Black and White Copier Logo
111 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
