Hiya I have a 32 inch 32/1480-gb-11b-eg-uk it was on with USB in the TV crashed turned off back on for 5 mins sed USB found and then switched off and won't come back on
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
  • 125 Answers
SOURCE: Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Posted on Mar 14, 2009
  • 1077 Answers
SOURCE: lg 32 inch lcd on light flashing white but fast
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a badcapacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
  • 1961 Answers
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
  • 335 Answers
SOURCE: i have a sony bravia lcd tv of 32 inches bearing
This seems like a T-con board problem as its responsible for several picture functions including color convergence. Or it could be a bad LVDS cable (inside the TV) I can ship you a new T-caon board for $150.00 or take it too your local shop repair shouldn't cost more than $250.00....
Posted on Oct 18, 2010
How do I fix a 32 inch 32lg70 smart tv that has sound but a white screen
unplug for 5 min at least the hold the power button on the tv not the the remote then plug back in and turn on
May 31, 2016 | Televison & Video
My Pc USB port speed has suddenly decreased dramatically :(
You may need to defrag the computer and your memory stick.
Jan 20, 2013 | Computers & Internet
32 inch LCD sharp tv switches audio from mono to sterio every 4 to 5 min
When you are connecting this television to a signal source with a coax cable this happens. The solution is to connect with an RCA/composite cable instead and utilize the television's inputs instead of using input tv.
Jan 16, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Used insignia 32 inch with DVD. want to reset
most manafactors codes are 1234 or 0000 or 5555 or 8888 you might have to put extra didget on EG 12345 -00000 - 55555 -88888 but if you changed it sorry dont know
Nov 10, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Problem with 32-inch Toshiba flat screen tv
yes take it back sounds like a back light issue
Jan 04, 2009 | Sharp R-1480 Microwave Oven
Ilo 42 inch plasma
call for a fix ya technecian around you
Oct 11, 2008 | iLO 3200 32 in. LCD Television
Turn off /turn on
I have an 32 inch Akai TV/DVD Combo; the TV turns off by itself about every 20-30 min, and when I put in DVD to play, the TV cuts off.
Jan 30, 2008 | Akai LCT3215/26 32 in. LCD Television
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
