Question about Vacuums
How do we replace the dirty water tank clip as it has come off
How do you put water into the tanks for cleaning. I see the 2 in 1 tank but can't figure out how to get clean water into the reservoir>
easy one the tank separates , there a clip that is on the flat side of the tank assembly, there is a handle to pick it up, half round handle. On the flat edge you"ll see the clip., unfasten the clip and the top and bottom separate, below is what looks like a hot water bottle,you fill that bladder with hot water, the outside plastichousing stores the dirty water, once full, a level sensor will rise and the vacuum will stop sucking! thats it!
Aug 16, 2014 | Vacuums
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Why is the recovery tank on Hoover f6212-900 not filling up?
Hello! There are a few things that can cause the cleaner to lose suction. Please try these quick steps.
1. Remove the dirty water tank.
2. Clear the filter screen of any dirt or debris.
3. Turn the cleaner on, check your motor suction by the filter screen.
4.. Replace the dirty water tank making sure it is flush to the cleaner on all sides.
5. Lift up on top of nozzle and slide off cleaner.
6. Wipe debris off nozzle and front of cleaner with a damp cloth.
7. Replace dirty water tank.
If you felt suction by the filter screen your suction should now be restored. Hope this was helpful!
Jul 21, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    Need directions to fill , and how to use
    Hi
    I have one just like it. Lay the machine back by pressing the pedal on the left side of the machine with your foot. Now you can get to the handle for the clean/dirty water tank. Lift this off. There's a clip in the back to separate the top sweep section from the tank. Take off the top. You'll see an open hole on the top for filling the bladder inside. This is for clean, hot water only. Fill the bladder, around the bladder is where the dirty water goes back in. you can drain the dirty water by pouring out the corner. There is also a plug on the bottom for draining the bladder when you're done.
    When you put the sweep section back on the tank be sure to catch the front part over the edge of the tank or it won't stay on. Then fasten the clasp and put it back in place.
    To fill the soap dispenser... find it at the back of the machine at the bottom. It just lifts out of the machine. Fill to line and reinsert.
    Hope this helps.
    Handy Andie
    Mar 20, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
    Empty dirty water tank, replaced it and then started to clean again. It did not **** up the water.
    The only reason for no pick up is an air leak. The most likely problem is that the lid is not properly seated on the dirty water tank. A less common problem is that the round rubber seal the tank sits on is out of place.
    Jan 28, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
    I have never used a shampooer before when I use it it says to empty out dirty water. I don't have any left. My tank is empty. Am I doing something wrong.
    Suggest that you do the following.
    Remove the TOP ("Clean water") tank. Fill it 1/2 full of water. Put the top on the clean water tank and place it back on the machine.
    Release the machine handle and remove the cover of the "dirty" water tank. Inspect the back of the tank to be sure that the vacuum adapter in located in the rear of the dirty water tank. If not-that is your problem. If yes, restore the top to the dirty water tank.
    Power the machine on.
    On a kitchen floor, power the machine on. Pull the trigger and hold it for about 30 seconds. You should see water gathering around the brushes. If not, that is a problem.
    With water around the brushes, release and lower the handle and and move the machine over the water. It should vacuum the water into the dirty water tank.
    Is all of that happening?
    Nov 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Hoover steam vac
    in most cases you will need to replace the dirty water tank assy. this is usually around $40 to $50.
    Aug 14, 2008 | Hoover F7431-900 SteamVac Vacuum
    I HAVE A BISSEL SPOT BOT THAT WON'T **** UP THE DIRTY WATER.I TRIED TO TAKE IT APART TO CLEAN IT, BUT DIDN'T GET VERY FAR. ANY SUGWSTION? THANKS, ...
    No Suction
    Possible Causes Remedies
    Tank is full. Empty tank.
    Dirty/Collection tank latch is not down. Push latch down, securely
    into place.
    Black Valve on the Dirty/Collection Tank is missing. Replace Black Valve into Dirty/ Collection tank.
    Usually there is a seal out of place, or a filter is clogged, so you lose suction.
    Apr 30, 2008 | Vacuums
    Emptying the powerbrush
    Gently
    press the Quick Release tabs on the Clean/Solution Tank
    and slide the tank off of the unit.
    Grab the Dirty/Collection Tank and pull to remove.
    While at the sink, remove the Tank Cap by turning
    approximately 1/4 turn counterclockwise and lift
    out the cap.
    Empty the tank. Rinse the Dirty/Collection tank with
    warm water.
    Replace cap and turn approximately 1/4 turn clockwise,
    until snug.
    Slide the Dirty/Collection Tank into the unit. Replace the
    Clean/Solution Tank.
    The tabs on the side is what locks the tank on, if they won't release the tank, then you may have to take apart to get it off and replace the tank.
    Jan 30, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
    Vacuums Logo
    24 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
