Question about Toshiba Televison & Video
Need code to program Toshiba TV model no 55SL412U serial No B20192M12491K1
    Top Expert:
  • Toshiba Master
  • 74,999 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on Dec 10, 2016
  • 1694 Answers
SOURCE: need code to program tv ...........T.
Posted on Apr 08, 2008
  • 67 Answers
SOURCE: Programming Code for a Toshiba TV
Try these codes:
1000, 1048, 1072, 1105, 1109, 1118, 1160, 1190, 1241
Posted on Jun 11, 2008
SOURCE: need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Posted on Aug 28, 2009
  • 207 Answers
SOURCE: i require the tv universal remote code to program
i cant give u the exact one ull have togo thru these and find the one that works but here nthey are 0002 0502, 0906, 0112, 0512, 0520, 0115, 0701, 0402, 0805, 0407 one of these 4 digit codes should work just keep tryin them until u find the right one hope this helps
Posted on Feb 24, 2010
SOURCE: need programing codes to run my cble, vcr, and dvd
i need the code for my toshiba ct90159
Posted on Jun 02, 2012
TOSHIBA 55SL412U wont turn on
If fuse should blow up, surely there should be a resown for that. You must first check out the reason, and then insert an other fuse of same rating. If you wish to get some details, Pull up older posts. Check for damaged component/s at its main power supply regulator board.
Dec 22, 2013 | Toshiba 55SL412U LCD TV
How do i change the the antenna from cable to antenna
which of these TVs is yours?
Originally supplied with models: 19AV600U, 19C100U, 19SL400U, 22AV500U, 22AV600U, 22C100U, 22SL400U, 26AV500U, 26AV502R, 26AV502R/U, 26AV502RZ, 26AV502U, 26AV52R, 26AV52U, 26C100U, 26C100U1, 26c1100u, 26SL400U, 32AV500U, 32AV502R, 32AV502RZ, 32AV502U, 32AV50SU, 32AV52R, 32C100U, 32C100U1, 32C100U2, 32CV510, 32CV510U, 32DT1U, 32E200U, 32RV530U, 32SL400U, 37AV500E, 37av500u, 37AV502R, 37AV502U, 37AV52R, 37AV52U, 37CV510, 37CV510U, 37E200U, 37RV525R, 37RV525RZ, 37RV52R, 37RV530U, 40E200U, 40E200U1, 40E200U2, 40FT1U, 40G300U, 40G30U, 40RV525R, 40RV525U, 40RV52R, 40RV52U, 40XF550U, 40XV640U, 40XV645U, 40XV648U, 42AV500U, 42RV530, 42RV530U, 42RV535U, 46/40/55S41U, 46G300U, 46G30U, 46RV525R, 46RV525U, 46RV530U, 46RV535U, 46RV53CU, 46SL412U, 46XF550U, 46XV640U, 46XV645U, 46XV648U, 52RV, 52RV530U, 52RV535U, 52RV53U, 52XF550U, 52XV645U, 52XV648U, 55G300U, 55HT1U, 55S41U, 55SL412U, 19AV600UZ, 19SL410U, 24SL410U, 32C110UM, 32FT2U, 32SL415UM, 40E210U, 40SL412U, 55G310U, 42RV525R, 32C100UM, 32DT2U, 40E210U1, 65HT2U, 32RV525RZ, 46RV525RM, 40G300U3, 46G300U1, 32C120U, CT90302 Programming Instructions and Codes, CT90302, 75022871, 75017678, 32E20U, 37E20U, 40E20U, CT90325, 75028874, 24SL410UM, 32C110U, 32SL410U, 32SL410UM, 40E210UM, 46G310U, 32C110U1, 32DT2U1, 40FT2U, 32C10U, 19L4200U, 24L4200U, 32L4200U, 40L5200U, 46L5200U, 50L5200U, 26C100UM, 40E200UM, 55HT1, 50L2200U, 39L1350UC
Jan 12, 2013 | Toshiba Ct90325 Remote Control
My Serial number is 94590994 and I cant tell what universal remote I need. TV is Stuck on channel 2
Do yourself a favor and save time, money and aggravation and locate an original remote, universals if they will program will be missing key features the original had.
If you insist on a Universal, use your computer and Google with the model number search for remote. that should give you a few hundred different remotes that might work.
Dec 15, 2012 | Toshiba 32A33 32" TV
Need a manual for Toshiba model 55sl412u
The number you gave is actually a TV not a laptop.
Try here:User Guide
Jan 26, 2012 | Computers & Internet
How unlock tv toshiba 55SL412u
if you don't have a manule i would type in the model number and you will be able to down load one but becarefull thier are alot of scamers that try to get you to download a viras try the manufacture site
Oct 20, 2011 | Toshiba 55SL412U LCD TV
Tv set up codes for a toshiba
Here is a link to help you reprogram your remote. LINK
Nov 20, 2008 | Toshiba Satellite A135 Notebook
Need code to program toshiba tv with Direct tv remote
Oct 01, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
