Question about Philips Audio Players & Recorders
Is Philips HTS3565/98 firmware upgradedable? - Philips Audio Players & Recorders
Command disk not foud while operating
My suspect is your DVD player has aborted a previous firmware upgrade process. Usually DVD players use firmwares burned on a DVD/CD, the complete process takes a couple of attempts to successfully flash the firmware.
The best way to get the command disk or ROM disks is to check the Philips website's support section for your particular DVD player model. Unfortunately, Philips does not offer command disk / firmware patches for all models.
Last but not least.. take your DVD player to the nearest Philips Customer care. They should be able to fix it.
Mar 04, 2011 | Philips Televison & Video
Corrupted Firmware on Philips HTS3555 Home Theatre System
Only posibility is finding a service shop that services Philips....
Mar 23, 2010 | Philips HTS3544/37 Theater System
Is there firmware update for Philips DVDR 3455H ?
Well you get your firmware from below link -
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_HARDDISK_RECORDERS_SU&session=20090905122441_125.63.122.112&grp=HOME_ENTERTAINMENT_GR&ctn=DVDR3455H/37&mid=Link_Software&hlt=Link_Software
Good Luck!!
Thanks
Jul 14, 2009 | Philips DVDR3455H/37B
Firmware
The firmware has corrupted.
Run the Philips Device Manager, installed from the driver CD.
Connect the PSS110 to the mains and PC, when the Philips Device Manager registers that the device is connected click on the Restore option, and follow the on-screen prompts.
This will format the device and replace the corrupted firmware.
NOTE: ANY TRACKS WILL BE DELETED
Apr 25, 2009 | Philips PSS110/17 MP3 Player
Phillips 4GB
Get the firmware update from the philips website
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Oct 29, 2008 | Philips GoGear Flash MP3 Player
Philips GoGear mp3 model: SA1300
3. Enter your model # SA1333 or whatever
-Tha Mp3 Doctor
Sep 03, 2008 | Philips SA5125/37 MP3 Player
Sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
Sep 03, 2008 | Philips GoGear SA178 MP3 Player
DOWNLOADING MP3 PLAYER TO WINDOWS VISTA LAPTOP
For Vista compatibility with the SA6045 -
-Tha Mp3 Doctor
Aug 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Does not turn on properly
Firmware manager should solve this problem.
  1. First Make sure that you have your PC connected to the internet, as the firmware manager will download the firmware from the firmware server, it is necessary that you have the PC online during the entire the process.
  2. Run the application on your PC at Start->Programs->Philips Firmware Manager->Philips Firmware Manger.
  3. Connect the GoGear player with the PC in normal mode. Switch on the player.
  4. Firmware Manager will start the upgrade process after the player is detected.
  5. Enter the serial number of your device. You can find the serial number as a 14 digital code printed on the sticker near the USB connector of the device e.g. SFxxxxxxxxxxxx and then click NEXT to proceed.
  6. Click the START button, select the firmware and click OK.
  7. The upgrade process will continue to download firmware.
  8. Once the upgrade process is completed, click FINISH to close the application.
  9. You may now disconnect the GoGear Player from your computer.
Mar 02, 2008 | Philips GoGear SA178 MP3 Player
32 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
