I keep getting a error stating faulty hardware such as a hard drive or cd rom Status error
  • Curtis k Dec 10, 2016
    I'll undo it all tonight and try again cuz the first time I messaged you was cuz I had tried what you said before u told me to do so and then restarted n still the same errors this time the whole back is coming off and checking all wires cuz it starts up fast but goes straight to the error screen
    Top Expert:
  • Computers & ... Master
  • 24,763 Answers
Check the cables are connected correctly and the hard drive is connected firmly and try again.
Posted on Dec 09, 2016
SOURCE: Windows XP Unsuccessful on Start Up
when i turn on my pc the screen just goes black and doesnt load or do anythink what is my problem
Posted on Feb 09, 2008
SOURCE: Toshiba Laptop will not start up!Toshiba A135-S4666 lap top satellite
i have had the samething happen recently it seems if you disconnect from internet prior to logging off take out the battery after shutdown leave it out till nexttime you need the com itll start i tried this the last couple days after a month of it not starting right or not at all tried all the solutions posted this has worked for me i took out the little battery that keeps the clock set at right date and time so when i do get it started i just click on the clock and reset the date and time i dont know if pulling the battery is necessary but i actually snapped mine by mistake but atleast i can get it too start so far everytime thank god for little miricales acers ok but not ths model for sure themodel is ace 5050 aspire
Posted on Sep 14, 2008
SOURCE: Windows has encountered a problem communicating
I had similar problem with a Dell Optiplex 760 desktop . I went to BIOS disable external SATA and all additional ports which is not used like parallel and serial ports and it worked. I think its with SATA settings only .
Posted on May 25, 2009
  • 788 Answers
SOURCE: Windows boot manager-hardware failure
Try pressing F-8 and look for last known good working configuration.
If you are trying to reload from CD/DVD drive and it continues to boot into your old windows configuration, Enter your BIOS settings, and change the boot order to CD/DVD and then Hard drive
Posted on Sep 15, 2009
  • 56 Answers
SOURCE: Windows boot manager page with status 0xc00000e9
If you don'yt have a Vista DVD,you can borrow any for startup vista repair. This is very common and HP/Compaq don't usually give operating systen vista dvd
Posted on Oct 12, 2009
HP proliant DL380 gen4 PXE-E61, when trying to install redhat and solaris.
First, it's not booting from a CD or Hard Disk if you've reached that error. The 'last-ditch' effort to boot is to attempt a PXE boot from the network card, but your Ethernet cable isn't plugged in. Unless you know you've setup such a PXE boot server, you'll want to check the BIOS settings to be sure the CD-ROM is set to boot first, followed by the Hard Disc. Be sure you have Disc 1 of the Linux installation set in the CD-ROM Drive and reboot. If you don't get the install screen, you may have another issue (bad CD-ROM Drive, bad cable/controller, no power to CD-ROM, etc.)
Another note on the DL380, if there is a RAID controller, you'll need to setup the RAID before installing the OS. You'll want to make sure your hard drives are properly installed and aren't failed. The RAID configuration screen will verify the RAID status once it has been initialized, which will somewhat verify the drive status.
Nov 12, 2013 | Computers & Internet
Hello, Im having a problem with my Dell INSPIRON 1750.
it's possible your hard drive has gone bad, that's what it sounds like
Aug 02, 2012 | Dell Inspiron Computers & Internet
Windows Boot Manager message: Windows encountered a problem communicating w/a device connected to your computer. Error may be caused by unplugging a removable storage device such as an external USB Drive...
Make sure there is nothing attached to the laptop,remove all devices like keyboard,mouse, flash drives and retry. If still having same error flip the laptop over and remove the battery and open up the 2 other compartments that have a screw holding them. One holds the memory modules and the other the hard drive, check and re seat all connections, then try again. If you still have the same error your hard drive is most likely failing,
Thanks for using FixYa
Jul 23, 2011 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
Turn on an Asus eeepc1000 netbook with windows xp and the following is what came on the screen " Windows could not start because of a computer disk hardware configution problem. Could not read from...
this could be caused by a number of problems
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 28, 2011 | ASUS Eee PC 900, 900A, 901, and 1000...
Windows failed to start. A recent hardware or software change might be the cause. file\boot\bcd status 0xc000014c info an error occurred while reading the boot configuration data.
Check the hardware connectivity of your Hard drive and Cd rom drive. Check if the wires are plugged properlyand are not loose. This error is generally thrown when your system is not able to find the boot sector in other words it is not able to find all he information (all necessary file pointers, kernel info And Master Boot Record etc) which it needs to start the system.
In most cases this is a temporary issue and occurs due to loose connections of the cables from Hard drive or CD Rom ( if the system is being booted up from CD).
Nov 18, 2010 | Computers & Internet
When I powered down and rebooted I got Windows Boot Manager Windows encountered a problem communicating with a device connected to your computer. This error can be caused by unplugging a removable storage...
hmm seems a lil odd it appears that maybe your internal computer hard drive is failing or that its not properly connected if its happened recently with no internal computer changes then its definitely the hard drive failing on you
Apr 22, 2017 | HP Compaq Presario SR1110NX PC Desktop
Need a system recovery? Tried the F8 method--doesn't work! Help!
Just unplug the hard drive cable and plug it again. otherwise if problematic replace the cable.
Apr 24, 2009 | Gateway GT5404 PC Desktop
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
