Evaporative cooler model ev 290 not working. What would be the problem?
3 Suggested Answers
jas247
  • 844 Answers
SOURCE: Need an owners manual for
Welcome to FixYa.
Click >>HERE to download the manual. It opens in Acrobat (PDF). If you do not have an Acrobat Reader, you can download the Adobe Acrobat Reader from this link http://get.adobe.com/reader/
Thank you for using Fixya. Have a great day.
Jas247
Posted on Jul 17, 2011
SOURCE: evaporative cooler not getting water from water line
If you are not getting water to your cooler, check your water valve where is connected to supply line. Check your supply tubing for kinks. Check your float for a bent rod or internal stoppage. Here in El Paso TX we have a lot of lime and calcium in our water that can cause blockages
Posted on Aug 14, 2013
Evaporative cooler, flap on roof will not open?
Most rooftop evaporative coolers use a gravity activated damper called a barometric damper. They do not use electricity and can often be found in the ductwork that bridges the cooler to the roof.
Look for a metal plate on the front of the ductwork held on by two screws. Remove that and you should be able to remove the damper to service it or replace it. You can find replacement evaporative cooler dampers online if need be.
Jan 08, 2010 | Mastercool 67471 Evaporative Cooler Air...
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
The Mastercool cooler is not cooling. It is only
Can you see if water is on the pad?If it is the humidity level outside might be too high,above 15-20%. the dont work too well.good luck.
Jul 11, 2009 | Speed Port-A-Cool 16" Evaporative Cooler...
My husband wants to install a mastercool evaporative cooler in a building that is completely open on one side. We live in AZ.
It will work fine as a spot cooler if he has direct airflow on him, otherwise it wont do much for cooling the building.
Jun 30, 2009 | Mastercool 67680 Evaporative Cooler Air...
Water on the squiral cage side I don't know where its coming from
I don't know exactly what you mean by getting water on the dry side of the compartment. In any event, as you will see, there are very few sites that are dedicated to the maintenance and repair of evaporative coolers--you, in fact, submitted this problem of yours under the Air Conditioner section because there is no Evaporative Cooler section.
Having said this, I offer you two things: 1) a site that has a section dedicated to evaporative coolers, which took me a long time to find for my own problems:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers.htm
and 2) the general idea that if you have water where it is not supposed to be, it likely is because there is a hole---obviously caused by rust--that allowed such water to get penetrated through. See more on rust holes of coolers here:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers_Cooler_Has_Holes.htm
This should help get you on your way.
Brad
Jun 08, 2009 | Mastercool 67680 Evaporative Cooler Air...
Evaporative cooler pumps in dust
You should not have dust. Your water pump is probably shot. The hoghair might need to be replaced or the whloe unit might need a good hosing down. As far as a draft all the time? That is what you want in an evaporative cooler ain't it?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 16, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
