WHAT IS THE thrust washer - Washing Machines
  • Washing Mach... Master
  • 3,828 Answers
Special washer takes up the movement of the adjitator
Washer Thrust Washer part 285587 How To Replace
Posted on Dec 09, 2016
Tip
Thanks for the detailed instructions. I've just done this repair and after...
This advice is for certain Maytag TOP LOADING washers equipped with a vertical transmission and drive belt system.
Loud squeaking noises during the wash cycle or, at the end of the spin cycle, can be attributed to a worn snubber ring and/or brake assembly. The snubber is a plastic ring located under the tub support. It helps to reduce vibration as the tub agitates and spins. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is located to get rid of some noise related problems (this will be the round metal plate where the tub support meets the bottom casing of the machine). A worn snubber will also cause some vibration or out of balance problems. The brake tends to glaze over after it has become worn and will squeak or cause sudden jerking of the washer when the spin cycle stops. If the corn starch tip does not get rid of the squeaks, I would recommend replacing the following parts:
Brake Stator
Brake Rotor and Lining
Snubber:
You will need: Brake Removal Kit*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs brake spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself.
The parts required to make the repairs aren't very expensive, but the tool required to do it can cost about $100. This repair I would rate as DIFFICULT for the average do-it-yourselfer. If you've never worked on this type of washer before, this is not a job that I would recommend. However, Maytag DOES provide informative how-to instructions with all their parts.
To replace the snubber and brake assembly:
1. Remove the front case of the washer to access the washer interior.
2. Tilt the washer towards the back and remove the drive belt. Slide the drive motor towards the center pulley to relieve belt tension.
3. Remove the drive pulley by removing the center cap and retaining ring from the drive shaft. Remember how these components go back together. There should be a couple of plastic drive bearing pieces and some metal washers above the pulley on the shaft.
3. Lower washer and remove hoses from the wash tub.
4. Remove the suspension springs. NOTE: Pulling the wash tub towards the spring you are removing will release some of the tension on it.
5. I usually remove the entire wash tub with transmission still installed at this point and place it upside down outside the washer for ease of accessing everything. (There are other methods, but I find this one easier).
6. This is where the brake compression tool will be required to remove the brake rotor, stator and snubber ring. (Instructions come with the tool). Basically, it involves compressing the spring by turning the compression tool CW with a wrench, loosening all the bolts on the brake stator housing, and then slowly turning the compression tool CCW.
7. The brake compression tool is removed at this point and the snubber, brake rotor, brake stator and brake spring can be accessed.
8. Replace any worn parts, and reassemble the brake assembly. DO NOT forget to place the brake spring back in place before putting the brake rotor back on.
9. Place the tub assembly right side up and lower back into washer.
10. Reconnect all hoses back to wash tub.
11. Reinstall all tub suspension springs. NOTE: It’s easier to start in the back of the washer and work your way towards the front.
12. Tilt washer back and reinstall drive pulley. NOTE: When placing drive pulley back on shaft turn pulley slightly to ensure it is seated all the way on the shaft. NOTE: If the shaft had multiple metal washers, you may only need ONE after replacing the snubber ring. Retain the extra washer for later use if needed. If the drive pulley is reinstalled correctly, a groove will be visible at the end of the drive shaft for the retaining ring to go back in place.
13. Reinstall drive belt.
I hope you find these instructions helpful.
on Apr 27, 2009 | Maytag Atlantis MAV6000 Top Load Washer
What is the purpose of the thrust washer on the front axle differential of a 2003 Silverado 4x4?
a thrust washer is there to take up lateral movement in the differential, if the washer is not their, their will be to much side movement in the pig assembly and it could bind and brake the case or the pig ( carrier assembly )
Mar 12, 2011 | Chevrolet Silverado 1500 Cars & Trucks
I have a magic chef 20 lb capacity heavy duty washer model W20HN3S serial ME851474 with spin problems. Clothes come out soaking wet. Can I replace a belt?
If your washer will wash (agitate) your clothes but does not spin well, you will need to replace the "thrust bearing" in the washer. The repair is simple and will only take you a short to do. Here is a link to the "thrust bearing kit" you will need.
Jan 07, 2011 | Chef Cooking Magic Chef Washing Machine...
Washer making rattle noise during wash and spin cycle
I would agree with that diagnosis. That is a symptom of a worn thrust bearing for sure and it is a quite common occurrence on your style of washer.
I wouldn't rule out debris in the drain pump as another possibility as well though, i.e. small stones, jewelry, etc. You may want to rule out that possibility before throwing money at a pulley & thrust bearing kit ( it is actually a "transmission pulley kit" which comes with a new thrust bearing as well ). part # 12002213 and retails for about $40-$50 see photo's below.
Hope that answer's your question. Let me know if I can assist you further and thank's for visiting "fixya" for your repair inquiry. Please take a second and rate this info I provided for you here.
Good luck.
macmarkus :)
Mar 16, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Thrust washers
Install it back as it is, *** it and test the motor for north to south free play, has to have not free play, fly wheel has to by *** and engine has to move free
Jan 25, 2009 | 1994 Isuzu Pickup
THE WASHER IS NOT SPINNED THE WATER OUT
Check the belt, the pump, and the thrust washer.The thrust washer wears down and won't release the tub. All these symptoms are easily repaired with minimal tools.
Jan 06, 2009 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
