Question about Smeg Ovens
Smeg SA398X. Oven start as normal then will stop heating.heat lamp off thermostat is clicking when passing the current temp function selector in off position the heat indicator light stays illuminated
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Posted on Dec 11, 2007
  • 146 Answers
SOURCE: smeg single fan oven
Before you change anything try the broiler circuit. If the broiler works then it could be an element if not then you could have a problem with the oven thermostat.
Posted on Dec 24, 2007
SOURCE: OVEN will not heat
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at jodunn5555@aol.com Good luck
hongster
  • 6 Answers
SOURCE: Smeg SNZ91MFX1 Fan heating not working
It could be that the element around the fan (which is obscured by metal plate) has gone. Remove the metal plate in front of the fan, and test with a multimeter to see if a current gets through it...
Easy to order and replace yourself
Posted on Jan 24, 2008
barkencoa
  • 3463 Answers
SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Posted on Jan 02, 2009
Smeg pyrolitic oven is setting an alarm off on clock after we set the required temp it will start to heat up then the alarm goes off if not quick enough to reset clock, it then locks the oven door
in cleaning a pyrolitic oven is suppose to lock the oven door , this is a safety feature due to fact that oven gets up much higher in temp than a normal oven , the heated air it produces if let out would flash burn anything in front of it to ashes (people,pets,rugs,etc.) the clock doubles as your display window to see what temp oven is at , there should be a clock selection to see current time of day even if oven is in use , and last but not least , it has a delay cleaning start feature , you can set it to come on and clean it's self , Id recommend not to use this feature for safety reasons (I don't think the mfg thought that feature out too much )
the door should remain locked till oven temp is below a preset minimum safe temp ,id not force it open for safety reasons
Sep 28, 2015 | Smeg Ovens
Smeg linear oven is displaying sho (showroom mode) and will not heat up. I have held down function knob for 5 seconds which clears SHO from display but within seconds it comes back. Any ideas
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 28, 2013 | Smeg Linear Pyrolitic Single Oven Electric
New (graded) smeg scp399x-8 no heat on any of the functions
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
Apr 07, 2013 | Smeg Ovens
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
SMEG OVEN BRAND NEW WON'T HEAT
Sep 08, 2012 | Smeg Ovens
Smeg oven stopped working
Jan 27, 2012 | Smeg Ovens
The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Aug 14, 2010 | Hotpoint Ovens
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
