Question about Frost Refrigerators
Frigidare frost insidegalaxy side by side is getting warmn ot cold and has frost on inside what can be the problem?
gaeb7
  • 25 Answers
SOURCE: water not entering freezing tray on frigidare side
Try replacing the washer in the solenoid valve. Sometimes it leaks by enough to freeze in the dispensing tube.
Posted on Feb 26, 2009
carputers
  • 255 Answers
SOURCE: Inside coils are getting cold with frost, no
check volts at fan if u have 120 at fan and fan not turning replace fan.
Posted on Sep 24, 2009
iwillfixforu
  • 619 Answers
SOURCE: Refrigerator side of this side by side is not getting cold enough
The frost is on the back wall of the freezer causing poor air flow to the rest of the unit. If you remove the back wall inside the freezer you will find the ice burg that sank the titanic. Using a hair dryer you will need to defrost all of the ice off the evaporator coils. There are 3 things that will cause this, Defrost timer, defrost t-stat or the defrost heater. Usually it is t-stat or heater. Good luck and hope this helps.
Posted on Mar 20, 2010
heatman101
  • 43501 Answers
SOURCE: frigidare model # frs26znh freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 13, 2011
cyrus_mansoo
SOURCE: My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Posted on Mar 08, 2012
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Jennair refrigerator (Model #JCD2389DES) does not stay cold. The freezer is cold but the fridge is room temp. There was a bit of frost inside the freezer. Looked up some advice and was informed that...
clean the coils under the ref will help it to run less and cool better . and make sure the fan under there is going also . but the ice or frost that you found in the freezer is the problem . it has block the air flow that cools the fresh food side . this is caused by 1 ot three things . i would replace the defrost terminator on the top of the cold coil first and if this does not correct problem replace the defrost control ( timer or some times called the A D C . ) part # 6100 5988 ) the heater is pr # 61006199 and comes with the terminator . hopt this helps mm feed pack please ..
Jan 01, 2011 | Refrigerators
In the freezer compartment, there is frost in the back. It's a side by side 19.9 without a water dispenser. The refrigerator part is not as cold as it should be but it is cold.
although most frost free freezers will hardly ever frost up,some will,(it depends on overall humidity)by frost free the makers say "food is frost free"but the inside is shinny plastic and all shinny surfaces will collect condensation and frost up.(look under the salad crisper,condensation?)it is worthwhile, about once a year,doing a complete defrost(NO sharp objects)and vacuum out all the vents/clean out any drain holes.
saves you a fortune in power.......
Jul 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How do I check if defroster heater is bad? On a Frigidare Side by side Mod FRS26ZSE?
if the defrost heater is gone you will have a large frost build up in the back of the freezer side.
Jun 11, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer sides works, refridgerator side will not get cool, any quick fix, I am pretty adapt mechanically
There is a good chance that the evaporator on the refrigerator side is frosted up due to a faulty thermal fuse or sensor or both. Since these units have more than one evaporator, there is no damper to get stuck.
May 27, 2010 | Samsung RS2556 Side by Side Refrigerator
Nine y/o GE side by side not getting cold enough
More likely a defrost heater. Look inside the freezer at the back wall. Any frost there? If so, turn off refrig., unload freezer, take back panel off inside freezer, and use a hair dryer to melt off the frost. Replace the defrost heater located at the bottom of the frosted coils. (New heater may appear different than original, but instructions are included) If you don't have the defrost heater on hand, just manually defrosting the coils and re-starting the refrig will get is cooling again for at least a week before problem will re-occur. (this give you enough time to get the replacement part)
Mar 21, 2010 | Refrigerators
Mar 19, 2010 | Kenmore 50522 / 50524 Side by Side...
I have a 4yr old 13.7 cubic upright frigidare freezer. Running all the time, I defrosted it recently (only minimal frost/ice on base behind basket) after noting top shelf warmer than others and food...
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
Vic
Jun 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Side by side, freezer is cold, fridge is warm, freezer is iced-up
Hi: Your defrost heater ot timer is out. Hence the frost. That also clogs the airways to the fresh food compartment. If you are handy, unload the fridge (you will need a cooler or have a bbq for everybody,) I can't give you the specifics but you will need to remove the panel where the frost is, first let the frost melt off. at the bottom of the coils will be a heater tube. Usually glass with a metal coil in it. See if there is a break in the coil. If so replace it. If that is ok it is your timer. Most likely electronic and expensive. This can be anywhere. Look at a diagram of the fridge to see. Sears parts is a good site for it. Hope I helped, Jeff
Jun 01, 2009 | GE Refrigerators
Refrig/Freezer not getting cold
If there is frost on the back wall of the freezer section a defrost is required. Defrost is normally automatic on a timed cycle. If you have frost and you know it is because of the door being open to long with the refrigerator running it could clear the coil automatically in the next 12 hours of operation. If it does not clear the frost from the coil inside the back wall you may require service to check out the timing device, heaters, and defrost thermostat.
Mar 07, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
37 people viewed this question
Top Frost Refrigerators Experts
jdthefixer
Charles T Nevin
Charles T Nevin
Mike
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
