Question about Furuno GPS
Just turned on my furuno gp7000f this morning and the screen came up with grey screen and say it initializzing. Any ideas
Hi there , my name is darrell , i turned my furuno tz14 on this morning and i have no detailing on my chart , it still shows me waypoints etc but no detail
Try changing range setting. Also try reseating the chart card if you're not using the built-in NOAA charts.
Dec 27, 2014 | Furuno Boating
Unit cuts out on engine start
will not enter navigation.
Jul 16, 2013 | Furuno GPS
Water temp settings
Hello
Go to page [2-6] of its user manual. All adjustments to be done to get the water teperature has been described here with details. It is difficult ot get all these details by this window, as it contains tables and charts, whci cannot be uploaded by this window. OK.
Jan 04, 2012 | Furuno GP7000F/NT GPS Receiver
How do i reboot my furuno navnet......recently installed radar and system not recognising teh radar installatio. no count doen on radar page greyed out overlay icons on the screen
Press and hold the "MENU" button during power on. Release "MENU" after boat appears.
Go through the installation wizard. You must select the radar type, "B" is 1834.
May 21, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
GP700F Airmar P66 to TM260
you must run 50KHz for deep water, so you will have to solve the interference problem to benefit from the power
Oct 12, 2009 | Furuno GP7000F/NT GPS Receiver
GPS/plotter/sounder will turn on and operate properly. Unit will
Try removing your chart card then powering up your unit. Chances are your chart could be bad and is causing the problem.
Jun 08, 2009 | Furuno GP1850DF GPS Receiver
Furuno sounder trandecer problems
the leading edge of the ducer should be higher than the aft portion. The leading edge must not be below the bottom of the transom. To determine if it is turbulence or radiated interference, put the boat in neutral and run motor up in RPM, if it fails then, with boat stationary, then proximity to motor is a problem and you should buy and in-hull ducer. glueing the transom ducer may or may not work well.
Aug 27, 2008 | Furuno GP7000F/NT GPS Receiver
1723 Furuno
are you in salt water? yes furuno can fix and reseal, but saltwater inside can not be stopped and you should cut your losses. If you wish, place a desiccant pack inside the unit. that is one of those little silica gel packs that you got with the christmas presents. Be very careful and precise with the rubber seal and you may be able to seal it back up. Temperature cycling can draw in humid air which can not escape, so open it, put a couple of desiccant packs in there, or ship it to Furuno. If the board is corroded, forget it, the board costs too much!
Aug 04, 2008 | Furuno NavNet vx2 1920C GPS Receiver
How to reset unit
thanks my problem is fix
Mar 19, 2008 | Furuno GP7000F/NT GPS Receiver
Installation furuno GP7000F/NT
This unit has built in sonar, so no DFF1 is required. The 1KW transom mount is in stock here, with the proper Furuno 10 pin connector. That is all you need, the display, the power cord, the GPS antenna, the transducer and THE BOOK! We are a Furuno dealer in the Great Lakes
Mar 03, 2008 | Furuno GP7000F/NT GPS Receiver
GPS Logo
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
