Question about Pool & Spa
I have a Colliquip sand filter and when the pump is switched on, there is a leak at the joint where the pipe leads into the filter.
Can this be repaired ?
    Top Expert:
  • Pool & Spa Master
  • 8,163 Answers
If un screwable use Teflon tape
Posted on Nov 12, 2017
Healeyman
  • 1198 Answers
SOURCE: shallow well pump made by wayne well is 22 feet deep pump runs no
Inspect the jet thru the suction pipe or the removable plug if the pipe isn't inline with the center of the impeller. The jet is very small, and easy to get something stuck in there. Then prime and leave the pressure pipe closest to the outlet slightly loose to let air out. Once you get good pressure you can tighten the pipe. Sometimes you have to prime more than once to get all the air out of the well pipe.
Posted on Apr 05, 2009
  • 1779 Answers
SOURCE: Gas line is leaking.
You want to be very careful not to make any sparks while working on this. The obvious is smoking, banging metal tools around, etc. keep cell phones AWAY from the area. Pick up some rubber fuel line from the parts store. Be prepared for some gas leakage, have a plastic pan under the leak. Disconnect the line at the tank, have a piece of new hose ready to push on over the line to as close to the tank as you can, have the end away from the tank plugged up temporarily with a pencil or something that fits snug in it, then remove the rubber hose on the filter, and connect new line from tank to filter, check for leaks, hopefully it is the rubber line you replaced, or the end of the metal line, so the new hose will hopefully cover the corroded leaking area. Clamp and Dry off area and see if you can spot any leaks.
Posted on Apr 15, 2009
  • 19 Answers
SOURCE: my pool sand filter pump isnt filtering the water
could possbly be a bad gasket on the vari-flow valve. When is the last time you backwashed?
Posted on Apr 29, 2009
arauzvictor1
  • 466 Answers
SOURCE: replacing water pump and pipe that crosses through the engine
Ok if you replace the water pump has to disassemble the front of the engine time to remove the belt to replace the pump tube If you have to remove the intake manifold to ban the base where the nozzles and have a good space for I hope to change the tube will serve this thanks
Posted on Oct 18, 2009
  • 990 Answers
SOURCE: Hayward sand filter leaks
You can try different epoxy's but they usually won't hold as the filter expands when running this will break any seal where you put it.You can check into warrentys. A lot of these filters had good warrentys on the tanks that went longer than valve or internal's. if you have install dates and model #'s. Check on line with Hayward.
http://www.haywardnet.com/inground/products/manuals.cfm
Worse comes to worse you can drill out a small hole amd using stanless steel go with a bolt and nut with washers and rubber washers in the middle. when you set it seal it all with silicone and after it is tight let it set for eight hours or so. Good luck.
Posted on May 28, 2010
Where can I get a manual for a Colliquip P24 pump?
Pumps do not have sand!!!! ????
What is it that you have?
Apr 27, 2015 | Pool & Spa
How do you fill up filter after changing sand
Let's back up a few steps so that I am not assuming you have completed certain steps.
1. You would have had to disconnect all plumbing coming into the valve assembly on top of the filter.
2. You would have had to remove the screws holding the valve assembly and remove it from the top of the filter.
3. You would have had to remove all the sand from the filter.
4. You would have had to verify that the sand pipe and the laterals in the bottom of your filter unit are still connected and in the proper alignment.
5. You would have had to replace with new sand using the amount that is recommended for the size of your filter making sure as you filled with sand not to get the sand pipe and laterals out of alignment.
6. You would next have to put the value assembly back on and aligned in the same orientation when you removed it.
7. You would next re-connect all the plumbing hopefully utilizing slip-joint PVC connections so it will simplify this process next time you go to replace your sand.
8. Turn your pump back on and check/verify that you don't have any water leaking anywhere and your filter should be taken care of the rest so you are done and can move on to the next task on the honey due list.
Jul 25, 2014 | Hayward SAND FILTER, PRO SERIES
How to prime a sand filter pump
use a garden hose connected to house supply to fill the housing and pump head , after that Pump should be able to take over and use water pulled from skimmer , if all your joints and seals are good , if it looses prime ,even after resting for a little while , ck all your joints and seals for leaks ,remember not all leaks ,Leak Out some leak In !!
Apr 23, 2014 | INTEX Sand Filter Pump
My jacuzzi pump biulds up pressure to 39lbs when you it on the pressure drops to 10lbs ? and the pressure does not recover untile you turn off the water. it use to hold pessure enough to to run the...
Hi love ranch....
You have one or three problems.
1...Air leak on the suction side of the pump, loose filter housing, air leak at mechanical seal,crack in suction pipe, etc...check all suction piping for tight fitting fittings or glue joints.
2...Worn Pump...replace pump..(Doubt this one is your problem) unless you have a sand problem
3...Clogged intake filter...replace filter
Please take time to rate me
Sep 12, 2011 | Garden
Why is sand shooting back into pool
Inside the sand filter there are laterals that are PVC pipes with many narrow slots along their length. If a lateral is broken then sand will not be stopped by the lateral. Another possibility is that the part these laterals screw into is broken and sand leaks through. I hope this helps.
Aug 07, 2011 | Waterway 22" Swimming Pool Sand Filter W15...
Sand from my sand filter is going into the pool. I have a S 244T
Aug 05, 2011 | Hayward SAND FILTER, PRO SERIES
Done every thing suggested. Still doenst prime. should I fill sand filter?
No prime = either impeller problem, air leak, or blockage on output(bad filter or bad valve) My first choice is dirty filter. Second choice is impeller. Both easy to check.
If you have checked those than you probably have an air leak. Hold a very slow running hose over all pipe joints running into filter, while motor is running. Most likely place is the screw in fitting on front of pump. The water from hose will temporarily seal leak and it should prime.
May 29, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
How do i change the sand in the hayward model sp 711
Hello, 1 You need to unscrew the drain plug and screen (if it is still there!) at the base of the filter. 2 You can reclaim most of the sand by letting the filter drain through a sieve (lots of work) or use new sand. 3 Uncouple union joints or couplers that attach to filter head. 4 Remove filter head. 5 You can try pulling some sand out of the top. However, do not damage the filter fingers in the sand. 6 Use a hose to blast the sand out the bottom drain. 7 Inspect all fingers, replace if necessary. 8 After all is cleaned out, place finger mount inside filter. Cover top of mount with a cup or similar to keep the new sand out of the finger assembly. 9 Replace drain plug and screen. 10 Fill filter halfway with water. 11 Slowly pour sand in and spread evenly. 12 Remove mount cover. 13 Reinstall head, unions and couplings. 14 Prime pump and test for leaks.
Good Luck
May 13, 2011 | Hayward SAND FILTER, PRO SERIES
How do i change the sand in the filter? I am getting sand in my pool.
You will simply remove the old sand from your pool filter and follow the instructions from your users manual like you are adding sand for the first time. In case you don't have it, I am going to paraphrase it for you below.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
IMPORTANT: To prevent unnecessary strain on piping system and valving, always shut off pump before switching Filter Control Valve positions.
The correct amout of sand can be determined with this link: http://www.backyardcitypools.com/pool-filters/Filter-Sand-Requirements.htm
2. Set your controls to the backwash position.
3. Prime and start pump according to pump instructions. (be sure all suction and return lines are open), allowing the filter tank to fill with water.
4. Once water flow is steady out the waste line, run the pump
for at least 2 minutes. This initial backwashing of the filter is recommended to remove any impurities or fine sand particles in the sand media.
5. Turn pump off and set valve to RINSE position. Start pump and operate until water in sight glass is clear—about 1/2 to 1 minute. Turn pump off, set valve to FILTER position and restart pump. Your filter is now operating in the normal filter mode, filtering particles from the pool water.
6. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten connections, bolts, nuts, as required.
7. Set your filter to the "filter" position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Noise at the valve on the my Pro Series Hayward Sand Filter
yuo may have air leak check gasket if clean check the inlet pipe add siicon around
Aug 09, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
75 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
