Question about Dremel Tools & Hardware - Others
What is the part on a dremel 395 /5 that the collet fits into and fits into the plastic coupling part that goes to the armature? the thread is damaged
melnavz
  • 1226 Answers
SOURCE: Dremel 395 Type 2
hello,
try to find it here:
http://www.powertoolspares.com/parts2.php?model_ID=3057
may this help.
melnavz
Posted on Jul 23, 2008
  • 218 Answers
SOURCE: collet base removal
Try using a tapered wood screw or sheet metal screw as an extractor. Choose one of a size that will let its tip go down into the broken collet and get a grip when you twist it. If that fails, you might use a screw extraction tool.
Posted on Oct 13, 2008
rowdy45176
  • 2176 Answers
SOURCE: Dremel Model 395 Type 3 Plastic Drive Shaft
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
Posted on Apr 14, 2009
  • 700 Answers
SOURCE: can't unscrew collet
it is possible that you stripped lock mechanism on the collet, for the beginning, never, ever, use wrench to tighten the collet! just hand tied, if it slips, tight it bit more, but with hands only.
i never used wrench on the collet and never have any trouble with any of my dremels.
to close, just hold firmly in one hand pressing locket button, tighten up with other hand, to undo, reverse procedure.
if you find bit is too lose, then you have collet inserts, find that one which hold bit firmly and use it on this particular bit. standard collet is 1/8" (3.175mm), but in the set there are collets from 0.0394'' (1mm) to 0.177" (4.5mm). do not use wrench...
just inspect now if thread is not stripped, on spindle and on collar, if locket still hold, if these are damaged, you need to change damaged part. and follow the advice :-)
if you find this advice useful, pleasae do not hesitate leave your remark and vote4 for me, thanx!
Posted on Aug 02, 2010
  • 3 Answers
SOURCE: dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Posted on Sep 26, 2010
How to replace the spline and coupling
The coupler nut tends to be screwwed on so tight that even when undone, the collet has bit into the soft shaft of the tool. Holding the rotation lock button in, grab the shank with some strong needle nose pliers and twist the shaft loose or pull it off completely with the nut and then seperate the nut from the shank when it is out of the Dremel Tool. A lot of machine tools are tightened too much, which makes the shanks get all damaged so use only the required tension on that collet nut.
Mar 28, 2011 | Dremel Variable - Speed Multipro Rotary...
The blade assembly on my dremel will not come off. Is there a trick to this?The coupling seems to stuck.
Try some W-D40 and gentle hits on the coupling to liberate the chuck 3 pin holders.If you got this type of chuck:
r00130v1.jpg > Enlarge Image
4486 Dremel Chuck
The Dremel Chuck holds Dremel accessories without using a collet eliminating having to use the wrench and creating quick and e
Nov 08, 2010 | Dremel 395 Variable Speed Multipro Rotary...
How do you attach "multipurpose cutting kit model 565" to the dremel multipro model 395?
Remove the collet nut and collet then unscrew the sealing cap (black plastic ring), this has the same thread as the inner of the multi kit tool, so just screw on the tool then replace the collet and nut
Sep 14, 2010 | Dremel 395 Variable Speed Multipro Rotary...
How to fit a 225Flexi Shaft
remove collet and screw to those threads
Oct 28, 2009 | Sport & Outdoor - Others
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
Jul 17, 2009 | Dremel Variable - Speed Multipro Rotary...
My collet nut is stuck and I cannot remove it. Is there a trick to removing a stuck collet nut?
remove all the star head screws, unscrew the top plastic collet holding the plastic outer casing on. take a pair of vise grip locking pliers open the plastic casing just enough to expose the inner shaft inside the casing lock the vice grips onto the metal shaft between the bearing casing and the collet that is stuck enough to hold but not to dent it up. now that the vice grips are locked onto the main shaft get an adjustable wrench and size it to the collet screw size and turn it should come off rather easily or at least mine did just did it as i wrote this then screw the casing back together and happy dremeling hope this helps
Jun 27, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel Model 395 Rotator Stripped
I would send it back to Dremel, they have been AWESOME to do business with, I have sent in 2 of my rotary tools, and because they couldn't be fixed, they sent me new ones at no charge, also, just bought one of their 4" table saws (off ebay) that didn't come w/an owners manula, I emailed Drwemel, and got one in today's mail, pretty kool for an item they quit making years and years ago. Hope this helps
Jan 02, 2009 | Dremel Variable - Speed Multipro Rotary...
Using the flex shaft attachement.
I dont think it should get that hot. Dremel has a program for the 225 Flex Shaft and for 17.90 they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264. Their phone number is 1-800-275-2052. Hope this helps. Dave
Nov 02, 2008 | Dremel Variable - Speed Multipro Rotary...
Collet base removal
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
I can't get the head to open to take out the bit
Unplug it, then while pushing in the little silver button near the head use a wrench on the hex nut and turn counter clockwise about a 1/2 turn. Push the bit in, then pull it out (that releases the little fingers that hold it).
The silver button locks the head so it won't spin while you are changing bits. Always be sure it is released before plugging in or turning on the power.
Feb 19, 2008 | Dremel Variable - Speed Multipro Rotary...
Tools & Hardware - Others Logo
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
