Question about Hardware & Accessories
Timer indicatorblinks 6times and outdoor not running
    Top Expert:
  • 47,630 Answers
Try the manufacturer's website . we do not have their information database
Posted on Dec 09, 2016
GE timer 15164 240v.
Copy following link to identify GE 15164 timer and download possible manual and see wiring for 240Volt application
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Sep 11, 2012 | UPM 120V/240V Heavy Duty Outdoor...
Timer is programed & is currently in off state but my stuff is still on
Specifically which timer do you have??
1) Reset timer to Clear programming, and then reprogram being careful to avoid overlaps and conflicts that can cause timer not operate as expected.
2) Move timer to different outlet.
3) Test outlet with circuit analyzer
4) Try plugging different load into timer. For example a light bulb instead of pump.
5) Check rating plate on timer and on pump to see if they are compatible.
For example Sylvania SA-210 outdoor timer is rated for 1/4 Hp at 120Volts
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
While Intermatic P1261 timer is rated for 2 Hp at 120volts
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#outdoor
Jul 17, 2012 | Sylvania SA210 15 Amp Zip-Set Digital...
I have a Heavy Duty Westinghouse 3-Outlet Outdoor Digital Photocell Timer and the time keeps running slow. Does the unit need sunlight to run the clock or do I need to change the internal battery? I have...
1) No the timer has internal rechargeable battery.
Battery is not replaceable.
2) I test timers, 4-6% arrive defective. Most go bad within few years. Some last long time.
3) If you set timer to turn ON at dusk, and turn OFF 2 hours later, then reflected light or car lights can give photoeye feedback so timer thinks it's light. Timer turns off and resets. I don't know if this information applies to you.
4) Link shows timer and manual for Westinghouse
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any
do-it-yourself project.
Jan 13, 2011 | Heavy Duty Westinghouse 3-Outlet Outdoor ...
How to set a Noma outdoor timer
You posted under Noma timer.
Noma timers are one of the names used for Woods timers.
You posted under 6-button outdoor timer.
Here is a link to 6 button outdoor Woods timer, to help identify your timer.
If this is not your timer, scroll through page to identify timer.
Manuals are posted with each timer, add a comment with specific timer number if you want me to write out steps from the manual once you identify the timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
geno_3245_173.jpg 6 button outdoor 7-day timer
geno_3245_174.jpg 6 button outdoor Week timer
Dec 10, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do I set it and can I use it indoors?
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
To use timer outdoors.
Plug timer into wall.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
My HB31R runs slow. Is there any adjustment ability to the timer mechanism to achieve a correct 24 hour timer.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb31r.aspx
HB31R heavy duty 1800 Watt outdoor plug-in timer is one-piece unit that does not come apart for repairs.
Usually with these mechanical dial timers, when the clock motor starts getting weak, the timer dial starts to stall when tripper meets on-off lever.
And then timers runs slow.
At this point, the little plastic gears are getting stripped out, or the clock motor is overheating.
In either case, the clock motor is spiraling downward.
If this is new timer, take it back.
If this is older timer, the manual and fact sheet do not show a warranty.
New HB31R on ebay for $15
http://compare.ebay.com/like/250558888618?ltyp=AllFixedPriceItemTypes&var=sbar&rvr_id=181711814537&crlp=1_263602_304662&UA=WXF%3F&GUID=c8511cb512c0a0aad3e705a7fffd84ab&itemid=250558888618&ff4=263602_304662
Woods makes 1200 Watt outdoor timer, but lighter weight than Intermatic:
http://www.amazon.com/Woods-59204-Weather-Outdoor-Repeats/dp/B0014WRNNK
With larger heavy duty outdoor timers like the Intermatic T-101R outdoor 120Volt timer, you can buy the clock motor separate and replace when clock goes bad. And you can buy the trippers separate. However T100 series timers are not plug-in, they are hard-wired. T-101 is made to last 10-15 years, but cost $60-70. My local Lowes sells them in stock for less.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Dec 08, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Set timer for the 7-day outdoor timer i.e. 5:00 pm on and 9:00 p.m. off Also set the clock ~ should it be left 'on' for the timer to work? Have lost the manual our programmer
Outdoor timers
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
HB88RC timer
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC Manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Timer takes AA battery installed from back
Instructions say: Set timer to AUTO using MODE button. This will let programs run.
To override current program, press MODE once for ON-or-OFF override.
Press MODE again to enter RDM or random mode. RDM shows on display.
Press MODE third time for AUTO. Usually, AUTO will show on display.
Dec 05, 2010 | Intermatic HB88RC - 7-Day Programmable...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
