Question about Home Security
How do i get the combination - Home Security
I have a brand new Travel Pro suitcase. I want to set the combination lock. How?
Some Travelpro bags come with an external lock upon purchase included in the user information package with the user manual and the add-a-bag strap or hook. This external lock can be looped through the zipper openings to secure your bag. To set the lock to your combination, follow these steps.
  1. External Travelpro Lock:
  2. Unlock the mechanism by pulling up on the metal lock rod. The 3 dial combination must be set to (0-0-0) factory combination if new, or the existing combination if used to unlock.
  3. Once released, rotate the lock rod to align with the notch of the dials, usually perpendicular to the long side, or about 90 degrees from its lock position.
  4. Select a new 3 digit combination.
  5. Press down the lock rod all the way and hold in that position while you turn the dials to reflect your new combination. NOTE**The lock rod must be held down all the way until you have your 3 digit combination in place, otherwise an unknown combination will be set while you adjust the dials.**
  6. Once your new combination is in place, release the lock rod. This sets the new combination.
  7. Return the lock rod back to the locking position and double check that your new combination does lock and unlock.
  8. Scramble the dials in order to keep your luggage safe and secure.
Jul 01, 2017 | Luggage & Travel
Im looking for the total combination for this nuber 13 20 31 36 41 45 permutations i think its called
Do you want combinations or permutations? They're different things. A combination of n items taken m at a time, sometimes written "nCm", selects m items from a group of n without regard to order. A permutation of n items taken m at a time, sometimes written "nPm", selects m items from a group of m with regard to order.
Given six numbers, there are six combinations of one number, 15 combinations of two numbers, 20 combinations of three numbers, 15 combinations of four numbers, six combinations of five numbers, and one combination of six numbers.
Given six numbers, there are six permutations of one number, 30 permutations of two numbers, 120 permutations of three numbers, 360 permutations of four numbers, 720 permutations of five numbers, and 720 permutations of six numbers.
Oct 22, 2014 | Office Equipment & Supplies
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
Number combinations
One-number combinations: { 1 2 6 9 }
Two-number combinations: { 12 16 19 26 29 69 }
Three-number combinations: { 126 129 169 269 }
Four-number combinations { 1269 }
Or did you want permutations?
Jul 07, 2014 | Computers & Internet
I have 11 numbers. I want to use those 11 numbers to create 7 number combinations.
Does every number have to be taken only once?
If order is important you have 11P7=1663200 permutations (different from combinations)
If order is not important for example 1,2,3,4,5,6,7---- 2,1,3,4,5,6,7----2,3,1,4,5,6,7----2,3,4,1,5,6,7 etc are all one and the same then you have
11C7 =330 combinations.
You get them by mere obstinacy: take a pad and start. It is only 330.
Dec 13, 2013 | Office Equipment & Supplies
Does anybody know how many different combinations there are for the numbers 1, 2, 3, 4, 5 and 6?
That depends on how many of those six numbers you take.
If you only take one number, there are six combinations: {1}, {2}, {3}, {4}, {5}, and {6}.
If you take two numbers, there are fifteen combinations: {1,2}, {1,3}, {1,4}, {1,5}, {1,6}, {2,3}, {2,4}, {2,5}, {2,6}, {3,4}, {3,5}, {3,6}, {4,5}, {4,6}, and {5,6}.
If you take three numbers, there are twenty combinations.
If you take four numbers, there are fifteen combinations.
If you take five numbers, there are six combinations.
If you take all six numbers, there is only one combination: {1,2,3,4,5,6}.
In general, if you take 'm' objects out of a set of 'n' objects, the number of combinations is given by n!/[(m!)(n-m)!] where '!' is the factorial operator.
Apr 30, 2013 | Mathsoft Computers & Internet
How many combinations for the numbers 1, 2, 3, 4, 5 and 6?
If you only take one number, there are six combinations.
If you take two numbers, there are fifteen combinations.
If you take all six numbers, there is only one combination.
Apr 30, 2013 | Home Security
I previously set my combination and it worked fine. Now my combination will not work on my cal pak lock luggage. how can I open now and reset combination?
Try rotating the numbers on the combination dial three times to clear any previous entry (stop on the zero's if this applies) and enter your combination one more time to see if this works and gets it open.
The default is 000; to set it, hold the lock open, move the dials to your numbers, and close/open three times. This will set the combination to your numbers.
Aug 27, 2011 | Locks & Locksmithing
Cannot unlock my husbands tsa lock we are in argentina
To set/reset combination on TSA Cable Lock
TSA Cable Locks come preset from the factory to 0-0-0. Set the combination to 0-0-0 or your already chosen combination. if different than 0-0-0. To set the combination, use a pointed device such as a pen to press in on B. While pressing on B (do not release B until combination is set), pick your 3 digit combination.
Once all 3 dials are set to the combination you want, release B. Your TSA Cable lock Is now set to your combination. TSA Lock will NOT be locked at this new combination - turn one or more dials and your lock will be locked. To unlock, follow instructions above.
Please make sure to remember your combination!
You can also use the video below:
http://www.youtube.com/watch?v=OfchUwkEckI
Good luck..
Aug 26, 2011 | Locks & Locksmithing
How to reset the combination, GE Hide a Key Storage Lock Box (GE Access Point Series)
Step 1. With the cap closed, set the numbered dials to the combination line. The factory preset combination is "000".
Step 2. While maintaining the combination in place, rotate the "RESET" dial indicator beneath the letters approximately 90 degrees to line-up with the combination line. If the correct combination is not set, the "RESET" dial will not rotate.
Note: Using excessive force can damage the dials.
Step 3. Set the new combination while maintaining the position of the "RESET" dial.
Step 4. While maintaining the combination in place, rotate the "RESET" dial back to the original position. The combination has been changed.
Sep 07, 2010 | GE Home Security
Home Security Logo
35 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
