Question about Home Security
How can i get in if i locked the combo in the safe
Don't want anybodythat might know my original safe combo to get in it door open cover off know original safe combo have all other info of ownership can I change combo of 1250 sentry safe
If the door is opened..Then you would need to remove the cover to the lock at the back..You will see a screw on the last wheel of the lock..Move that screw into a different hole on the wheel..Then you can dial the wheels to the lever..Each wheel is a number..This will give you a new combination..My advice to you would be to locate a Safe Tech/Locksmith..Have them do it for you..
Apr 18, 2017 | Sentry Home Security
My cannon safe with a s&g lock will ot open
[PDF]Cannon Safe Owner's Manual
https://www.cannonsafe.com/media/manual.../CannonOwnersManual.pdf
*EMP Lock is not available to retrofit on other safes; not sold separately. Page 9. Page '. 7. NL Lock. Programing the lock. Step 1. Open the safe door (factory code is ... Low Battery Warning: The lock will repeatedly beep during unlocking.
Opening a Cannon Safe with S&G lock set on factory combo ...
? 0:41
https://www.youtube.com/watch?v=XlYxrWhSLwE
Nov 6, 2008 - Uploaded by gunsafeman
opening a Cannon Safe with combo of 1,2,3,4,5,6 #
Nov 07, 2015 | Locks & Locksmithing
How do I lock safe.
if your asking how do you lock a safe that has the keypad.. you MUST know the 4 diget Combo.... enter your combo and hit the close button.. to open.. enter the combo and hit the open button.. hope this helps.. your question didnt give much detail to it..
Dec 23, 2014 | Locks & Locksmithing
Trying to open the safe, it's not opening and keep beeping?
you only get three chances to enter combo correctly then you must allow it to rest for 30+ minutes (even if you have correct combo)
Sep 18, 2013 | Paragon Lock & Safe SureDrop 7925 Digital...
I have a Sentry safe S5741. I have the electronic combo and the key. The door to the safe was locked with the door open. Now the door will not unlock to shut the door. Is there trip to reset the door? Is...
Try changing the batteries first. No the electronic combo would not be erased unless someone previously changed the combination. There is probably something causing the bolts to not retract. The lock may fail if there is any pressure on the bolts and or the door of the safe. Hopefully this information helps.
Jul 12, 2011 | Sentry Fireproof Safe
I forgot my combination i tried putting a couple different numbers in after three trys the key pad locked and now when i type any numbers in it doesnt work. how do i unlock my safe?
after 3 trys the keypad does go into lockout mode but it should only last for about 15 minutes and then let you retry 3 more codes to try and open. if you still do not know what the combo is you can usually call the maker of the safe and with the serial number you might be able to get the original combo that the safe was set to when it was purchased ( this is a factory set combo ) --- now if that does not work, your next step will be to call a safe tech ( locksmith ) to set up a auto dialer,, this takes about a full 24 hours to get the combo right. the safe tech can also drill a small hole behind the dial and manually remove the locking bolt. after the safe is opened the locksmith will fill the hole and reset the combo for you ( also replace the battery at this time too ).
c...
Jan 15, 2011 | Stack-On Stack On 16 Gun Safe with...
Sentry safe model SC3877 lost original factory combo..Does anyone know it..
Each safes ships with a different factory combo. You need to contact Sentry at 1-800-282-1438 for further assistance, or follow this link to the web site
http://www.sentrysafe.com/CustomerCare/
Dec 29, 2010 | Safe International Digital Electronic Safe...
The wrong number was input and now we can't get into the safe, we don't have a key for it, and the batteries seem to be flat. What can we do? The safe is an electronic digital safe GX B0709
You don't know the combination code, and you don't have a key? Or you know the right combo code, but the batteries are dead? If you have the right code, and the batteries are near-dead, try the jiggle suggestion...put the safe on you lap, put in the correct combo, and jiggle the safe while turning the latch. Might work.
Feb 17, 2010 | Safe International Digital Electronic Safe...
I Have The Key But Cant Remember How To Turn It And The Combo
The only way you can use the combo is to take the safe to a lock smith
Apr 20, 2009 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Apr 18, 2009 | Sentry Fireproof Safe
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
