Question about Garden
I have a unionpower up-150 pressure washe, and it wont pressurise
Hi, i have a unionpower up-150 pressure washer, the engine runs sweet as a nut, once the water is connected up and the lance is on, and ive got it running, when you pull the trigger it wont pressurise the water coming out, and the engine dose not dip(dont sound like its getting any load) please help, this was a gift thank you in advance!!
Mattie
Either your valves are stuck or broken or the seals inside the pump are worn
Posted on Feb 02, 2011
  • 3,600 Answers
Try pulling on the end of the wand that may solve your problem
Posted on Jul 20, 2009
Motor starts and cuts out when using gun now wont start
About 622,000 results (0.78 seconds) Search Results
    Troubleshooting Your Pressure Washer - Jacks Small Engines
    www.jackssmallengines.com/diy/troubleshooting-your-pressure-washer/
    Mar 18, 2015 - Or, you are in position to start washing, you pull the spray-gun ...Inspect hose for any twist, cuts, bends or dents. ... Your Engine Won't Start or is Lacking Power ... carb got motor running now hoses leaking and little water coming outof a ... I have a troybilt with a Briggs & Stratton engine 3000 max pressure.
    How to Fix Washer That Won't Start ' Washing Machine Repair
    www.partselect.com/Repair/Washer/Will-Not-Start/
    Find out how to repair a washer that won't start by troubleshooting and testing common parts like the ... Read on to learn how easy it is to fix the washing machine yourself. ...ApplianceHelp.com is now PartSelect.com .... If the motor starts, then the problem iswith the transmission or the pump and can be further diagnosed by ...Missing: gun
    Washing Machine Won't Start ' ThriftyFun
    www.thriftyfun.com/Washing-Machine-Wont-Start-1.html
    This is a guide about washing machine won't start. You have ... Is the motor burnedout? My wife was ... My Maytag Neptune was running; then the power went out andnow it won't restart. By Larry L. ... Question: Washing Machine Starts to Fill and Then Stops. When I try to ... It has something to do with the door lid. I usually ...Missing: gun
Jan 28, 2016 | Washing Machines
I have unionpower up-150 washer it wpnt start stood for a while
hi
not sure what engine is on this unit but I assume it is a honda engine or copy of on your unit as that looks like a standard engine on this model. If it has been sitting for a while then take the barb off...remove the two nuts on the front holding the carb cover on plus the bolt under the air filter. Pull the carb off the engine and remove the bowl. look for trash and old gas buildup inside the bowl. clean if needed. Remove the plastic float needle in the carb. in the center you will see the jet...you can remove the jet with a small flat screwdriver. Take it out carefully so as not to mess it up and clean the holes in the jet thoroughly. Reassemble the carb and replace on the engine. It should start with new gas. Good luck!!!Check here for new parts if needed Pressure washer parts catalog quick links Pressure Washers High Pressure... or FIND PARTS FAST
Feb 22, 2015 | Garden
Low coolant
have a pressure test done on the cooling system to find the leak. Check the heater core when the system is pressurised as well
Feb 18, 2014 | 1989 Chevrolet Suburban
Fuel wont stay pressurised in system if it sits for long time
check your fuel pressure regulator if is working or not. Just do a small and easy test about it. Do use a clamp and close the return fuel hose to tank ,start the car let it run for few minutes and switch it off. leave it for the same time you already did and start it again. If it starts easy then you prove that the pressure reguatort.
Oct 15, 2012 | Ford F-350 Cars & Trucks
I have a unionpower up 150 premium pressure washer theirs a small hose that comes out at the back of the engine with a small filter at the end of the hose pipe I dont no what its for
If the hose actually comes out of the pump (look carefully) it sounds like the chemical pick up line. It would most likely be clear plastic tubing with a plastic filter at the end. You drop this into your chemical (soap, etc) container and under low pressure it will siphon the chemical and apply it through the wand.
Jul 29, 2010 | Garden
Karcher hd 5 11/c pressure washer no pressure
Your problem is simply a worn bypass valve on its awy out. It still works enough for mains pressure but can not pressurise when drawing water.
Jan 14, 2009 | Karcher K2.26 Electric Power Washer
I have water leaking from the engine, but don't know where from. The radiator has been changed the water tested for emmissions, pressure tested and still water is leaking. The heating blows hot when...
if you see the water leaking form the front side of the engine usually from the water pump since the pump is not running you also wont get heat, bit when you pressurise the sys you are forcing the hot water into the core and you have heat, it is the water pump.
Dec 04, 2008 | Honda Accord Cars & Trucks
Washer cycle has stopped during the cycle and is showing FH wondering what the problem is, we can't find the manual
FH is usually a low pressure warning on the water supply.
You could try cleaning the small filter in the back of the machine, as it may have limescale blocking it.
If this doesn't cure it, you may have to just use a cold supply instead, or arrange to have a pressurised hot water feed.
This usually happens in bungalows and flats without enough hot water pressure.
Nov 05, 2008 | Whirlpool Washing Machines
Pressure washer wont idle and run
check the pressure replace valve or a bypass valve
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
441 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
