Question about Winter Sports
Carbarators. all adjustments and settings and the how two do. for an arctic cat 550 snowmobile
  • 53 Answers
SOURCE: pull clutch on arctic cat 700 snowmobile
you must buy the correct puller from a jobber or from artic cat dealer. it looks like a long threaded bolt that screws into the center of the clutch do not attemp to remove any other way you will damage the clutch or even worse the crank shaft. these pullers are usually around 25.00$
Posted on Apr 09, 2009
  • 12 Answers
SOURCE: 2003 polaris 550 trail touring,revearse not working
the high idle could be a dirty needle check your carbs i have that problem with my 550 rmk the reverse light could be your wire harness check your wires with any wire tester idk the specs for it but also clean your connections with some electrical wire component cleaner and use so di-electrical grease if all else fails you may need to bring it to a mechanic for a small fix like that it should run up that high
Posted on Aug 14, 2009
SOURCE: when replace a stator on a 1998 ZL 500 arctic Cat
i have a 1998 arctic cat zl 500, i think that i have an issue with my stator, i was wondering if it possible to test it without pulling anything apart just with the wires coming from the housing
Posted on Feb 05, 2010
  • 13 Answers
SOURCE: 1998 Arctic Cat ZR 600 Snowmobile dies out
air adjustment
Posted on Apr 18, 2010
FSAhead2
  • 214 Answers
SOURCE: ignition wiring diagram for a
this site might help , you can call them
http://www.brownsleisureworld.com/frame.cgi?url=http%3A//www.brownsleisureworld.com/snowmobile/Parts/
Posted on Sep 27, 2010
Pulled the plug wire off the right cylinder and it killed the engine
Electrical Diagnosis for Arctic Cats - YouTube
? 9:58
https://www.youtube.com/watch?v=iwwl4LPyOCY
Dec 29, 2009 - Uploaded by BlaineDP
When in the "OFF" position the switch will ground the ignition wireto the chassis effectively "grounding out" the ignition systemkilling the spark. ... becomes disconnected or if a wire gets cut then the switch will no longer turn off the engine. ... Testing a stator in a snowmobile Arctic cat - Duration: 3:25.
CAT AS NO SPARK!! - American Snowmobiler Magazine ...
cs.amsnow.com > ... > Forums > Manufacturers > Arctic Cat snowmobiles
If the connection to any switch; key, kill, tether, throttle safety switch, etc.. is ... Some older model Arctic Cats have the ground up closer to the handle bars on ... Here is a general rule of thumb for putting spark plug wires on which cylinder for Cats: ... Pulledthe ECU cover off and found some corrosion; I had a 580 that did not ...
Jan 16, 2016 | ATVs
How do the wires attach to the battery terminals on a '09 550 H1 Arctic cat ATV
Here is the service manual for your machine where you can see how the terminals are connected. http://www.mymowerparts.com/pdf/Arctic-Cat-ATV-Repair-and-Service-Manuals/
Mar 04, 2015 | Arctic Cat 2009 550 H1 EFI 4x4
My 2004 arctic cat pantera starts with the pull cord but not with the electric start. Turn the key and no response whatsoever. Any suggestions?
check all wiring connections and a switch under the seat like lawnmowers have. there may be a cutout switch under the seat.
Feb 02, 2015 | Arctic Cat 2004 Pantera 550
What causes the lights to flicker on a arctic cat 1992 ext 550
Usually a bad ground somewhere. Run the wires to see if there are any places touching that are bare. Mice love eating the coating on the wires. Thus causing you to have a flicker when it touches.
Nov 10, 2014 | Winter Sports
What would cause the lights to flicker on a 1992 ext 550 arctic cat
you have a bad wire rubbing against a ground,possibly where your handle bars twist on the harness.common problem with this modle.
Winter Sports Logo
108 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
