Question about Samsung SADT-100PM POLE MOUNT ADAPTER FOR PTZ CAMERAS
I can't remove numbers that appears in screen when i use a Samsung PTZ camera. Can you help me?
  • 31 Answers
Sounds like you are seeing a display generated from the PTZ camera itself. can you access the camera's menu?
Posted on Aug 23, 2009
I have a cheap floureen DVR security system. I'm attempting to contact a electric rotating bracket which pans and tilts (it allows me to connect my cameras to it). My question is can I run this with the...
U have used Qsee, Swann and Lorex. I have a PTZ that has worked on several systems. There is a set-up for the actual PTZ camera which you appear to be aware of. The App or program you are using has a set up for a PTZ along with on screen controls for it in the program. If the DVR you are using is not PTZ ready there is your answer. Should have a 2 wire acceptors one negative one positive.
The movement you are seeing initially, are the PTZ powering up and self testing. What brand DVR are you using, and is is compatible with your PTZ camera?? LOL Swann Tech Service said my Lorex PTZ wouldn't work with my new hi-res system. Well it does...
I will try to look for your reply to continue to troubleshoot for you.
Cheers,
Chance
San Diego, CA
Dec 12, 2017 | Cars & Trucks
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
I need to replace a Samsung SCC-641 can't seen to find any online.
I have two non working cameras with working power control plates if you are interested. Contact pbyer14@gmail.com
Jul 19, 2010 | Samsung Power Supply, Control Plate for ...
I'm having a problem with a Palco PTZ security camera where the screen is red and says video loss and from time to time video footage comes back for 2 or 3 minutes and then goes away
the first line of troubleshooting for this is to check your power and video connections on both ends of the cabling. ensure that the connections are tight and the fittings appear to be of decent quality and in good physical condition. If this does not solve, continue to replace power supply, if noy joy still, camera is at fault.
Aug 11, 2009 | Home Security
Camera would not pan and tilt power down at camera power backup now no picture this is a samsung JM-PTZ 220 SDN
if there is no display even though the camera works then this may be a problem with the display hardware.
Jul 27, 2009 | Home Security
I have an exterior pelco PTZ camera and the screen shows all Q's
The model number can be found on the back side of the dome drive and it would help to pull it out of the back box any way so you can cycle power to the dome drive....If the Q's do not go away call 1-800-289-9100 24/7 and you will get a live person in tech support and they can issue an RA number for repair....the estimate is free you just have to pay the shipping....Pelco is the best when it comes to warranty's and bending the rules for the customer on them....let me know if this helps and good luck
May 11, 2009 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
I have a samsung home security shr-1040 and i tried to change my password and i must have put a different 4 digit code than i meant, i am now locked out and cannot access my settings.....please help
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
Dec 25, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Installing a pelco ptz camera using my old controller
pelco cctv ptz doec not moving can you give me a solution?thanks a lot.
Aug 18, 2008 | Cameras
PTZ controls stop working
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jul 09, 2008 | Sony SNC-RZ30N Network Camera
Samsung SADT-100PM POLE MOUNT ADAPTER FOR PTZ CAMERAS Logo
142 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Colin Stickland
Colin Stickland
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
