Question about Tablets & eReaders
I have lost the numbers I need to unlock the tablet at start up. How can I reset this?
Iforgot my password to it and I need to reset it so I can get on it
To help you guide, how to unlock the tablet when you have forgotten or lost the login password. Please find the link given below and follow the step-by-step instructions mentioned on it:
https://us.en.kb.sony.com/app/answers/detail/a_id/34545/~/i-have-forgotten-the-pattern,-pin-or-password-needed-to-unlock-the-tablet
GuruAid.com
May 22, 2016 | Tablets & eReaders
I need to factory resrt MY tablet it is not booting up completely & keeps asking for a boot screen unlock code or pin number. Can u give a code or pin that will get me into my tablet?
you are going to have to reset it. you will lose all your info on the internal memory. take your sd card out to. different tablets reset differently. need you make and model to find the right way
May 16, 2016 | Tablets & eReaders
My kid locked her dl700d and now she cant unlock it
Typically only a factory reset will unlock it if the password is lost. It will wipe all data stored and reset to factory defaults. Then you can use it again as though it were new.
Sep 13, 2014 | Tablets & eReaders
How do i reset my password for my digiland 7inch dual core tablet my daughter forgot it and havein hard time resetting need easy way to fix
1) Power off the tablet. 2) Press and hold the Volume-Down and Power button simultaneously. 3) It displayed a menu in Korean/Chinese (?). 4) Scroll down (using the Volume-Down button) to the SIXTH menu choice. 5) Press the Power button to select. This will start the factory reset process. You will then be directed through the original start-up process as if you got it out of the box for the first time. If you have a Google account and if you stored your settings to Google, your previously loaded applications and saved contacts should start downloading. This is a factory reset, so everything not saved to Google will be lost.
Read more: How do i reset my digiland dl701q tablet when forgot pattern? - How to unlock a digiland tablet if you forgot your password with reset button :: Ask Me Fast at http://www.askmefast.com/How_do_i_reset_my_digiland_dl701q_tablet_when_forgot_pattern-qna8826890.html#q6437553
Aug 14, 2014 | Tablets & eReaders
Unlock craig tablet without gmail acount?
try starting it holding power button and volume up or down keys it should give you option to reset.let me know if you need more help.
Mar 31, 2014 | Craig Electronics 8" 4GB Android Tablet w/...
My tablet wifi is of and tablet is lock how we can unlock it
Only solution is to perform a hard reset but data in tablet will be lost.
Hard Reset steps are"
1. Power the Tablet off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5.- Select all Erase contents and settings
The Tablet will complete the hard reset process and reboot into a factory default state.
Oct 19, 2013 | Coby Kyros 716829701508 Tablet PC
NEED SCREEN UNLOCK CODE FOR ACER ICONIA 200 TABLET
Well, the only way to unlock your tablet is to factory reset tablet.
To reset tablet start the tablet, then hold volume up then select factory reset.
Sep 15, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Tablets & eReaders Logo
29 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
