Question about Home
How do I adjust my mantel clock so that it doesn't gain time every day.
  • 277 Answers
American mantel clocks will gain or loose 5 minutes in a week, that is considered normal. This article will help you to adjust your time using the pendulum.
http://usedclockparts.com/9-clock-case-repairs/31-how-to-speed-up-or-slow-down-your-clock-using-it-s-pendulum
Posted on Dec 21, 2016
Do you have an instruction sheet? How do I change the time?
open the little door at the back, you'll see a black box, in the bottom beside the battery is a tiny wheel, turn it to adjust time
Mar 10, 2015 | Home
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
My Welby mantle chime clock loses time, how do I increase the time speed?
You can speed up or slow down the clock by adjusting the length of the pendulum. This link will walk you through the process.
Jul 07, 2012 | Seiko Mantel Clock
Setting the time on a mantel chime clock
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Nov 07, 2011 | Seiko Mantel Clock
The clock runs fast , 20 plus minutes a day... Is there an adjustment and or how do I deal with this problem? Mantel 8 day clock. Thanks Ron
mcdevito75 here, There should be a F/S on the back of the clock, if so place it in the middle, if not, check out a small watcg repair shop in your area.
Jun 26, 2010 | Bulova Hyannis Desk Clock With Engraving...
The time and chimes are out of sync for our tempus fugit wall clock by 4 chimes does any know how to adjust it
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
Apr 24, 2010 | Seiko Mantel Clock
I purchased an old Hamilton mantel clock that did not run. I have cleaned and oiled it and now it works well except it losses five minutes per day. This has a German movement, spring escapement type,...
This clock has a floating balance escapement.
Hold the balance snuggly with 2 figures. Take a small screw driver and push one of the 4 legs above and attached to the disk to the "+" direction. Move it about 1/4 turn. Set the correct time and check again the next day. If the clock is still slow, move it again and set the hands. Do this until the clock is accurate.
Disclaimer: If this movement was made in the 1970 or early 1980's (The date is a 2 digit # above the movement model number). Those years the clock manufac. (Hermle) did not do well in quality materials. The may need an overhaul or movement replacement. I can provide more information if needed.
Apr 01, 2009 | Watches
Can not get this clock to chime at the right time
good after noon!just look at the back of your clock and you see the adjust button,press it to set the chime ! thank you! god bless !
Aug 28, 2008 | Seiko Mantel Clock
Home Logo
162 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
