I have a Swann Wireless SW347-WAK. It works OK from the control panel but when I reset the remotes it disconects the motion sensors. Then when I conect the sensors it turns off the remotes. Why???
SOURCE: help
wat is the make and model of the router?
try to upgrade the firmware on router to resolve wireless problems
Posted on Sep 11, 2008
  • 4 Answers
SOURCE: Solve my Laptop work wireless conection
This particular model comes with a built in wireless adapter. Make sure that the switch ( located in the front of the prtable) is ON. After this you shouldbe able to scan for wireless networks in range.
Posted on Dec 25, 2008
Skitrel
  • 19 Answers
SOURCE: xbox 360 wireless control conects then disconnects randomly
The solution is VERY simple.
There is nothing wrong with your controller OR your xbox.
The battery indicator found when pressing your xbox logo button is temperamental. It might say 2 bars, or 3 or even full battery but this is not a good indicator of a full battery.
The problem IS low batteries - when the batteries become low the vibration function can cause the controller to disconnect. This is happens because the vibration function uses extra battery power.
So basically... Every time your controller vibrates, it disconnects. This occurs when firing a weapon in most games, grenades in COD, landing heavy tricks in Skate 2, the list goes on, you'll find many complaints from people stating their controller disconnects specifically with these events.
The simple solution, turn off the vibration function when this occurs. It'll never happen to you again ^_^
Thumbs this up when it proves correct for you. People will find the solution quicker that way.
Posted on Jun 26, 2009
budmrtn
  • 11361 Answers
SOURCE: remote control sensor problem
Remote IR receiver:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LG+42LC2D+&stock=all&limit=20
You can find out when he will have it back in stock.
Posted on Jul 07, 2010
  • 74 Answers
SOURCE: Trying to add 10 window sensors to existing GE
First you need to have the installer code. Open the fromt panel of thealarm and enter in "4-3-2-1" (Default installer code) If it accepts this number then you can begin to program the doors and windows. If you don't knowtheinstaller code you mayneed to default the system and reprogram everything. If you contact meIcan walk you through the processor.
AlarmProfessor.com
Posted on Sep 05, 2010
Suddenly the tv box mk4 en remote stop working.
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Try a hard reset or a factory reset too; if the remote control is OK.
There are two methods to reset. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked above.
Jun 04, 2016 | Televison & Video
The remote turns on but cant select any buttons replaced the batteries and reset the pool panel
turn off remote then turn off aqualink turn aqualink back on then turn on remote if still doesn't work check 4 pin red plug inside panel at top if ok check to see if wire to antenna cut if ok open antenna and see if green and red lights are blinking
Sep 14, 2015 | Jandy Aqualink Pda Ps4 Wireless Handheld...
VISIO M470SL remote does not work. The remote is OK. Is it the IR sensor or the main board that needs to be replaced? VISIO M470SL remote does not work. The
If the standby light is ON at the front panel; when you power ON the set, and if the remote control is found OK too; the remote control sensor inside the TV is defective. Before doing anything, try by reset the set once.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 09, 2014 | Televison & Video
What kind of alarm equipment does the company provide?
Depending on what ur using it for .check out swann or logitech website
Oct 15, 2014 | Home Security
Remote controls, motion sensors don't work and their is no info. on the control panel.
If you want to realize remote control or parental control on PC,I recommend you to try professional third party software which has functions of site block and time control,etc.I have used parental control program of anykeylogger(www.anykeylogger.com),it works well,you can also find other fine programs on the Internet.
Nov 18, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have an ADT security system, the DCS alarm panel lcd5501z panel bypass motion sensors will not reset. The door and window sensors work fine when the alarm is set. but the interior motion sensors stay...
I would power down the main cabinet for 1 min. And unplug the battery in the cabinet. Most of the time this cabinet ( panel ) is located in a closet and contains the main brains of the system. Sometimes there is also a reset on the motion but when used, it can put the motion in test mode. You can also check the batteries in the motion ( if its wireless) The first thing I would do is power down everything and disconnect the battery. This resets and works 90% of the time. You might need the key to get into the box.
Sep 06, 2013 | DSC Power Series Lcd5501z 5501z Fixed Msg...
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Hi! I have a DVR4 2600 Swann, my cameras are working, but I can't get into the menu either directly on the DVR controls or via the remote???? I...
depress and hold the rewind button (<<) on the remote (or on the panel)until the units beeps.
It may take 20-30 seconds. or you may have to do it severalk times before you hear the beep. Once the unit beeps you should be able to get to the menu using the remote or the faceplate button.
Please note that the remote is infrared so the sensor on the faceplate is sensitive to where the remote is relative to the sensor on the faceplate.
Jun 01, 2012 | Swann Communications DVR4-2600 4 Channel...
Motion sensor wasn't working, replaced battery. Now says sensor tampered. How do I reset
In your motion there is a tamper switch. make shure your caver was properly installed.
at the panel enter your code as you would to disarm your system and repeat disarming a second time.
Nov 07, 2009 | GE Security Simon 3 Wireless Home Security...
LG Split system (ceiling cassette)
Check your remote control by using your camera or cellphone camera as your eyes. Point the remote control to the camera and "on" the remote control. If no lights emits in the remote control means that your remote control is defective If lights emits then the remote control is ok. Try also to locate the reset or rst button on the remote control if available and reset it, then try. If it wont work may be the receiver board in the unit is defective.
Jan 14, 2009 | LG LSC121PMA Split System Air Conditioner
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
